S54 Swap Modifications Available
  • John T
    • 413
    #76
    Tyler, has any of your customers put that much down, if its already been done I won't waste the effort to test?
    • TinyT
      • Jan 2011
      • 152
      #77
      I don't believe so! Pour on the power :).
      • John T
        • 413
        #78
        I'll keep you posted
        • amcink
          • 788
          #79
          Subscribed, can you do one for he e38?
          • gobuffs
            • Dec 2004
            • 513
            #80
            Anybody have a pic of the sway bar attached to front with motor in place? Preferable an M3 style with the mounting to the strut. What is the length between the sway bar and the subframe (IOW- the new width of the subframe if that makes sense)?
            • E30Strube
              • Jul 2008
              • 181
              #81
              No pics, but the width should be the same. All the new subframe does is relocate the mount from rear to front.
              • 89AlpineM3
                • 548
                #82
                I don't have a pic either but the distance is the same just flipped
                • Thing30
                  • 171
                  #83
                  Anyone looking to do the subframe modification, I am selling one so you don't have to drop yours while it gets fabd up. I can cut it and ship directly to T too. Tyler modified mine and it came out flawless. post pics soon.
                  Ham
                  • TinyT
                    • Jan 2011
                    • 152
                    #84
                    Thanks for the post Ham!
                    • anaphe
                      • Jan 2010
                      • 56
                      #85
                      Gobuffs ours is an m3 (suspension techniques) it worked fine we did have to shorten the drop links about 3 "
                      • anaphe
                        • Jan 2010
                        • 56
                        #86
                        Ours had to be shortened, keeping the m3 drop links the same length put the bar too close to the control arms
                        • gobuffs
                          • Dec 2004
                          • 513
                          #87
                          Good to know. Thanks. Hope to get my subframe back from Tyler soon.
                          • bm1956
                            • Aug 2013
                            • 5
                            #88
                            speed sensor
                            Hi tinyt
                            how did you get around the speed sensor signal or did you have it removed
                            l also have S54 E30 Sport
                              • 34844
                              #89
                              you can change a parameter to use the E30's VSS input
                              send me a PM, I can help.
                              • TinyT
                                • Jan 2011
                                • 152
                                #90
                                Thanks for the input Nando!
