S54 installation help.
  • Luis325
    • 3847
    Doing a bit of research for Fernflex whos planing of installing the s54 in his e30.
    He has the complete engine with harness and ecu all sensors etc.
    I know the reflash will be done with Mark D. But besides this what else would be neede to swap it into the e30?
    Oil pan?
    Engine mounts?
    Motor mounts?
    Trans? Can i bolt on the Getrag 260?
    Driveshaft?
    Im searching but there is not many info on this swap yet...
    Thanks for the help!
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
  • gobuffs
    • Dec 2004
    • 513
    Start here: http://www.r3vlimited.com/board/showthread.php?t=45442
      • 34844
      you probably want the M3's fuel pump, filter, and pressure regulator.
      • FredK
        • 14763
        You have a choice of oil pans. You can either use the E34 M50 oil pan and pump, or use a modified subframe and oilpan (TinyT modifies them).
        If you use E36 M50 aluminum engine mount arms, the engine will bolt up with the same E28 535i engine mounts as the regular M/S50 or 52 swap.
        The Getrag 260 transmission will work. However, you may want to consider using a 240mm flywheel, if you're going to use a stock-ish clutch.
        The driveshaft choice will depend on whatever transmission you use. It will be identical to the driveshaft choice as with the normal M/S50 or 52 swap. For example: If you use a ZF 320, you can use an E36 M3 or 328i driveshaft.
        • Fernflex
          • 264
          What about tuning? Mark D, Bimmerworld? Any other option?
          Is the car going to work perfectly, will the rev limiter be 8,000 rpm?
          I also need the vac vanos eliminator plus the vac drive by wire?
          Please Rate Me:
          http://www.r3vlimited.com/board/show...35#post3283535
          ________________
          1987 332i Track Car (253whp)
          __________________
            • 34844
            why would you need or want to eliminate the vanos?
            also, it will be cheaper to keep DBW, and easier. a DBW pedal is around $90 used, or free if it came with your motor, vs $300 for a DBW elimination kit, which really has no advantages.
            out of the options, I'd pick MarkD.
            • Luis325
              • 3847
              Fern i keep telling there are new and simple ways to do it.. not like 5 years ago where people had no clue how to do them...
              Its not that hard now... just cost more $$ because of the tune and wiring options,
              but what you payed for the engine,harness trans ($1,400) etc. when you buy the tune your still not in the price range of just an s50/52 engine cost...
              Do your research right, like i said call Rohan and ask people here on the forums like Nando and FredK, they now their shit!
              • Fernflex
                • 264
                What I have:
                S54 Engine, Harness, Ecu, Smg Transmission, pump lines and ecu. $1,400. ( Smg ecu, transmission and pump that I will sell)
                What I need:
                Mark D Ecu
                E34 Oil Pan
                E34 Oil Pump
                E36 Engine arms mounts
                E28 Engine mounts
                E36 M3 transmission
                E36 328i Driveshaft
                E36 Ring and pinion
                Clutch and Flywheel
                Brakes pads and Disc
                Calipers
                Wheels
                Tires
                Radiator
                Oil cooler
                Expansion tank.
                Vac Drive by wire elimination
                Anything I should add o delete from this list?
                I need all this because my e30 is 1987 (early model) and has 4 lug suspension.
                Please Rate Me:
                ________________
                __________________
                • Luis325
                  • 3847
                  Fern i said i wasnt going to say anything else and let you decide what evere you want to do... BUT youre like a my brother but your sounding like a vagina.... Keep the engine and SLOWLY read carefully SLOWLY gather parts and when you have everything you need/want the you swaop even if it takes a year...
                  Also you know there is the second option of a quick profit, ill give you $2,000 for everything...$600 profit for you... LOL
                  • Fernflex
                    • 264
                    For my m20?
                    Please Rate Me:
                    ________________
                    __________________
                    • Luis325
                      • 3847
                      hahaha for the s54... lol
                      • Wanganstyle
                        • 2828
                        I'd call ABL for the e-throttle delete. I disliked the experience I had with the VAC unit. Hardware is china crap; not worthy of the $385 delivered price I paid for it.
