M54 (dual vanos engine) swap thread. MS42, MS43, MS45.1
  • DesertBMW
    • Aug 2011
    • 1023
    #46
    Originally posted by mike25
    Hakentt
    I have one of Ergen Motorsports MS43 ECUs running an M54B30 in a non E46 chassis - it has the EWS working, so please do not tell me I know nothing about it I have the engine to prove it works.
    Ergen Motorsport in UK have worked out how to remove the CAN bus requirements, while leaving the EWS in place. I'm just trying to make sure others know there is finally a proper solution available - but of course they are a commercial company and will not give it away.
    Mike
    Idea is not to have EWS at all. It is called immobilizer off or removal of EWS anti theft system. My solution is pure software, I don't use emulators at all. Unlike Ergen M. my solution does not require EWS
    • kameleon
      • May 2011
      • 288
      #47
      I would rather use no EWS if you do not require it in a swap.
        • 34834
        #48
        deleting EWS isn't something that requires any particular amount of skill or intelligence. all it requires is the knowledge of the location for the byte that turns it off. It's literally changing a byte from something like AA to FF. that's it. Knowing where that byte is more luck than skill except for whoever figured it out first..
        • Leinad78
          • Jul 2015
          • 10
          #49
          Hakentt
          Its clear from reading many of your posts you know a lot, but by your own admission elsewhere you do not know how to work around the MS43 ECU - as you have stated your solution uses emulators and is a poor solution which will fail given time.
          Mike
          Could you do me a favour and have a look in the DME file if at position 0x300 is something like "JG&Marrakesh" listed? If so, that would just mean your tuner sells knowledge from those two guys.
          Like HakenTT aka revlimit aka wolvowitz aka wolvow aka DesertBMW did until Marrakesh made him pay big money for that approach ;D
          Unfortunally its more then switching one byte ;) But i´ve done it for you guys so we can enjoy beautifull engine swaps for free!
          • damodave
            • Jul 2015
            • 1
            #50
            There is a very nice man at BMW who figures all this stuff out, nobody else.
            It gets sold to some, then to others and others etc etc etc
            Hakken is a liar and an animal, all I see from him is lash up after lash up
            • 328ijunkie
              • May 2007
              • 3961
              #51
              MS43 EWS is alot more than a 'byte flip' thats why it took so long for people to figure out. The current solution is more of a 'hack' in the program space vs a 'bmw integrated' byte flip like MS41/MSS5X.
              Check Us out on Facebook
              Full Product Line Tuning
              • FredE30
                • Feb 2014
                • 6
                #52
                Bom dia
                Montei um M52TU 286S2 528i de 1999, em E30
                Este usa Sistema, Can Bus multiplexer
                Mantive EWS, juntamente com cave,
                Tenho um problema,
                cada conjunto de, unidade de motor, EWS e chave que troco,
                ele trabalha cerca de 20 vezes, e depois bloqueia e não pega mais.
                Talvez por falta informação (Can) de outras unidades (centralinas)
                mas não sei qual
                sabe como posso contornar esta situação, para resolver
                • DesertBMW
                  • Aug 2011
                  • 1023
                  #53
                  Originally posted by FredE30
                  Bom dia
                  Tenho um problema,
                  mas não sei qual
                  Esa problema tienes porque no instalaste "instrument cluster" es lo que manda senal de RPM a EWS.
                  • FredE30
                    • Feb 2014
                    • 6
                    #54
                    Já instalei painel de instrumentos, e nada,
                    mas não estou vendo, qual será fio de RPM,
                    mas tenho um fio, (nº13 EWS)---(nº7 painel instrumentos, ficha branca)
                    MS42
                    • DesertBMW
                      • Aug 2011
                      • 1023
                      #55
                      MS42
                      panel de instrumentos recibe senal de revoluciones RPM por CAN-BUS, luego manda senal por K-BUS a caja de EWS.
                      • FredE30
                        • Feb 2014
                        • 6
                        #56
                        Já liguei can-bus do painel instrumentos e caixa automática,
                        e não consegui nada
                        • alco
                          • Feb 2013
                          • 197
                          #57
                          DesertBMW,
                          Do you have a source for the following part numbers you mention in your updated post?
                          11411432735
                          11137502669
                          11417503261
                          It seems BMW NA has enforced the "no Euro parts for Americans rule"
                          Velocity Motor Works
                          1972 2002
                          1983 533is
                          1987 325is (Roxanne)
                          1988 M6
                          1989 M3
                          1989 325ix (Darth Maul)
                          Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
                          • mjsarraf
                            • Jul 2017
                            • 2
                            #58
                            Swap MS45 TO MS43
                            #15 Wiring harness. You will be only working with wire section that have 02 sensor plugs on it like you see in the photo. Simply remove the automatic transmission wiring from that harness, it has blue plug. Main ground wire is brown in color and it goes to chassis, it will have black sleeve on it. Direct 12 volt wires are 4 red wires that are in pairs on a black plug, simply strip them and install banjo connector and install them on 12+ from battery. The 12 pin black plug goes to main engine harness and 12 pin clear plug goes to chassis, that's where the starter and alternator wiring is at. I will cover the specific wiring in another thread.
                            Photo of the harness that you will be working with the most:
                            [img
                            http://s25.postimg.org/lnum21lbj/e30etaswapharness.jpg[/img]
                            You will have to use E39 temperature sensor on the cylinder head.
                            Clear 12 pin connector:
                            1.empty
                            2.empty
                            3.to starter black
                            4.empty
                            5.empty
                            6.alternator -15 white/green
                            7.red/white wire do not use
                            8.empty
                            9.A-OLD don't use
                            10.F-OLN don't use
                            11.unknown
                            12.empty
                            The dual 2 pin connectors with red wires are all 12+ constant battery
                            You will have to wire fuel pump relay the same way it is on E36, it is just basic 5 pin light green relay. The DME and Injectors relay is already integrated into MS42/MS43 harness.
                            on green 4 pin relay(61368366600) 85-86 is a coil, so pin 10 will go to one of them and other one goes to bat+ then Pin 30 is bat+ and 87 goes to power fuel pump.
                            40 pin X60004 plug wiring:
                            1: alternator charge indicator signal, [run this wire to inctrument cluster battery light]
                            7: ground wire for electronic pedal to pin 1 [MS43 only]
                            8: electronic pedal signal to pin 4 [MS43]
                            9: voltage supply for pedal pin 5 [MS43]
                            10: fuel pump relay activation ground wire [wire this to fuel pump relay, sends ground signal to activate fuel pump relay coil]
                            11: oil pressure warning light [wire to instrument cluster oil pressure light]
                            12: ground pedal sensor to pin 2 [MS43]
                            13: signal pedal sensor to pin 6 [MS43]
                            14: voltage supply for pedal to pin 3 [MS43]
                            17: RPM signal to instrument cluster
                            22: Speed signal [gets speed signal from E30 cluster]
                            23: Clutch switch signal [gets negative ground signal from clutch switch]
                            26: switched +12 from ignition switch
                            32: K-line to pin 7 of OBD2 connector
                            That is it for X60004 connector, no need to connect any other wires
                            Hello there,
                            Can you please explain that more which i swap my ECU put it won't work
                            Can u please explain it by viedos or pics which it can be more clearly for us
                            Thanks
