OBDII Connector to ECU
  • said
    • Jul 2006
    • 61
    Hi Guys!
    i bought a s54 form a totaled car, so i went and removed the ECU harness by cutting everything!
    i already got the wires together, but can't find were to connect the OBDII Port to the ECU.
    can't find any e46 schematics!
    can someone help me out by telling me where to wire each OBD II port cable?!?
    thanks!
    • 34839
    search for the WDS.. it's all over the internet
    • said
      • Jul 2006
      • 61
      i found that! but it won't open anywhere!
      I've tried in 3 computers!
        • 34839
        it has to be internet explorer and you need to make sure your java is up to date.
        • said
          • Jul 2006
          • 61
          u the man!!
          hahaha
          someone said in another forum that the cluster translated the info for the ECU... in my case, i don't have a cluster, how do i connect things so someone can flash it remotely?
          thanks!
            • 34839
            you don't need a cluster to flash the DME. either you were reading about something else, or they were mistaken.
            all you need is power (pin 1 and 16), ground, and K-line at the OBDII port and you should be able to use it to flash.
            • said
              • Jul 2006
              • 61
              thanks!!!
              • said
                • Jul 2006
                • 61
                so the OBD II only communicates with the ECU by the white/violet cable?
                just one cable does the entire flash and stuff?
                thats cool...
