Engine & Trans removal - what to keep?
  • cwatt
    • Oct 2012
    • 275
    Hey R3V,
    I'm going to be removing the engine and transmission from my project car to make way for an S54. Having looked into S54 swaps, I understand I'll be using the new DME but needing to keep some of the existing electronics. I'll also be going e-fan and it seems most take the swap as an opportunity to install a larger rad.
    My question is simply - what should I keep and what goes on Kijiji?
    thanks,
    - Colin
    • 34844
    You dont really need anything from the m20 that i can think of.
    You can use MSS54 to control your fan if you take the fan controller out of an E46.
