accelerator pedal position sensor problem after m54 swap
  • Ognev
    • Oct 2014
    • 7
    Hi, Guys!!!
    Ihave a swaped M54B25 into my e30. I've had troubles with the accelerator pedal position sensor. With ignition ON pedal work perfect ot live data, after start and run at idle pedal not working. The car donor is 2003 E39 with auto transmission with EWS 3. With BMW scanner 1.4 in IMMO put it to Manual. Search at advice where is the problem.
    thanks...
  • DesertBMW
    • Aug 2011
    • 1042
    I had the same problem. It is the brake pedal switch if you have connected everything else properly. You got to have INPA and watch the data, it will tell you "brake switch on/off and clutch pedal on/off" you must make both work. Then clear "all adaptions".
    • Ognev
      • Oct 2014
      • 7
      There is no clutch pedal switch, only brake pedal switch. Тhe clutch switch is not only to permit start engine? With brake on/off no difference
      • DesertBMW
        • Aug 2011
        • 1042
        Clutch switch is a must on MS43
        • The Dark Side of Will
          • Jun 2010
          • 2796
          Clutch switch interacts with cruise control, for example.
          • Ognev
            • Oct 2014
            • 7
            But how it`s worked so far on E39 without clutch pedal sensor?
            • Todd Black 88
              • Oct 2007
              • 3449
              Car was an e39 with auto trans. It wouldn't have had a clutch switch.
              Does it need one now that the auto trans is gone?
              Originally posted by codyep3
              I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
              2001 silver/Blk 325 cabby. SOLD
              2002 325xit Sil/blk. SOLD
              2010 F650gs twin
              • DesertBMW
                • Aug 2011
                • 1042
                you got to code the MS43 for manual and install clutch switch.
                • Ognev
                  • Oct 2014
                  • 7
                  today connected brake switch and everything is fine. thank you guys!!!
                  • DesertBMW
                    • Aug 2011
                    • 1042
                    Guys? I thought it was me who told you brake light switch right away.
                      • 34844
                      oh hakken, so conceited..
                      • Todd Black 88
                        • Oct 2007
                        • 3449
                        Better give this guy his props, or he will take his toys and go home.
                        2010 F650gs twin
