I responded to your PM. You may have a fuel pump relay issue. Check the signal wire from the ECU. I've seen different pin numbers referenced, so it depends on which harness you are using.
E30 S54 ess vt1 started only two seconds
Then you give to new
I plug in the box and EWS transponder and the function it well, but I still have the same problem
The car starts and stalls
I check the cables + and -
I also spend the diag
default throttle position sensor
steering wheel angle
oil level ( broken sensor)
vehicle speed
help me please
I know what to check
thank youComment
