E30 S54 ess vt1 started only two seconds
  • Soso Bc
    • Jan 2015
    • 8
    good morning
    I apologize in advance
    because I do not speak English and so I'm forced to use a translation software that is not always very understandable
    I just finished assembling a s54 smg change in manual gearbox and equipped with a compressor kit ess vt1
    I did re-encode the DME to the gearbox and remove EWS in a specialist in england
    My problem is that I have all connect
    The car starts 2-second stops
    pressure regulator Nuke 5bar
    Gasoline pump oem e46 M3
    I saw that other person had almost the same symptom
    thank you for your help
  • Soso Bc
    • Jan 2015
    • 8
    [IMG][/IMG]
    • gobuffs
      • Dec 2004
      • 513
      I'd suspect the EWS hasn't really been turned off.
      Any stored codes?
      • DesertBMW
        • Aug 2011
        • 1038
        two seconds run then dies is EWS is not deleted.
          • 34844
          Yeah, ews will not even let it start.
          • Soso Bc
            • Jan 2015
            • 8
            is this normal
            I must put my DME ground for the start relay
            or miss there a ground connection?
            • Soso Bc
              • Jan 2015
              • 8
              how to check if the problem just ews
                • 34844
                it's not. it won't start at all if EWS is enabled.
                • FredK
                  • 14762
                  Could the fuel supply and return lines be hooked up backwards?
                  It sounds like a fuel delivery issue. If you have the stock, non-return fuel rail, it definitely takes several cranks to purge the system of all of its air.
                  Good luck, and let us know how things go!
                  • 328ijunkie
                    • May 2007
                    • 3961
                    It will start then stall if EWS isnt nuked out
                    Check Us out on Facebook
                    Full Product Line Tuning
                      • 34844
                      are you sure? is the priming pulse enough to make it fire?
                      • 328ijunkie
                        • May 2007
                        • 3961
                        When i first got into this swap rodeo that was the exact same symptom i was experencing. Fires for 1-3 seconds then dies. MSS54 only, all other ECUs (MS41-43, etc) dont even try. Always wondered why that was :P
                          • 34844
                          I think the other ones don't fire the injectors at all. MSS54 definitely primes them, even when EWS hasn't been disabled. the priming pulse is just enough to fire the engine apparently.
                          I hope the OP didn't pay much for that flash if it won't even start!
                          • Soso Bc
                            • Jan 2015
                            • 8
                            I check my fuel system is ok
                            I has all the original boxes for EWS I is not against the electrical diagrams to connect
                            And I believe that this EWS system must also counter
                            that if you advise me to flash the DME as soon
                            • Soso Bc
                              • Jan 2015
                              • 8
                              I saw E30strube had a post with the same problem
                              but it does not mark how he had resolved his concern
