S54 e30 Low on power
  • Vrossi46
    • Jul 2015
    • 7
    Hi
    I was wondering if any of you could help me find out whats wrong with my s54 swap.
    Had the car on dyno after the build were done at it only made 308hp (engine hp)
    The engine seems to run ok, it revs 8000rpm. Only when im driving down the highway at 2-3000 rpm it sometims gets grumpy until i give it full throttle.
    The engine is an us 2001 model with euro headers and euro 2005 mss54hp.
    The alternator plug is not connected due to i run M50 alternator.
    Have som fault codes.
    51. DME: Interface, multifunction steering wheel (E46)/steering-colum stalk (E36/7)
    84. DME. CAN timeout DSC
    85. DME: CAN timeout, steering-angle sensor
    86. DME: CAN timeout, instrument cluster
    87. DME: No roadspeed signal
    2B. DME: Signal,temperature sensor, radiator outlet.
    2C. DME: Signal, thermal oil-level sensor.
    6A. DME: Signal, brake-light switch.
    8B. DME: Interrution, Tempomat operation
    ECU Information:
    BMW part number: 7836454
    Hardware number: 1
    Software number: 19
    Bus index: 60
    Coding index:00
    Diagnosis index: 30
    Date of manufacture, year: 05
    date of manufacture, CW: 25
    Production number: 52420290
    Supplier number: 0000115852
    Sorry for my rubbish english.
  • gobuffs
    • Dec 2004
    • 513
    From what you posted, you need to get the road speed signal fixed or get it flashed out via a tune. DME wants to see road speed. It wants to see it from the DSC unit. Not sure if you can send signal for diff into the proper wire into the DME. You really just need a proper tune with certain things turned off.
    I would say the last code is saying it is in limp mode.
      • 34844
      You can change the speedometer input to a standard diff siignal (z3m mode). You have to adjust the k factor so it reads the correct pulses/km.
      I would have the other errors removed as well.
      • Vrossi46
        • Jul 2015
        • 7
        Thanks. :D i will speak to my tuner and hear if he can fix this. =)
        • superleggeram3
          • May 2015
          • 119
          If the Vehicle speed rear right wheel speed signal from ABS is programmed out of the DME/disabled does this cure the issue ?
            • 34844
            you either have to delete the error codes for the VSS input, or change the input mode to "direct", adjust the K factor, and hook up the standard 9-pulse signal.
            • BMWfanz
              • Dec 2013
              • 46
              Could someone clarify- if speed signal in soft is in DSC mode and i connect on pin22 on x60004 connector speed signal from e30 dash- it will be still in limp mode and error on speed signal will be like no road signal at all?
                • 34844
                yes. in DSC mode it reads it over the CAN bus. It has to be set to "direct", which is what the Z3M uses. Then it will read the pin on the DME.
                • BMWfanz
                  • Dec 2013
                  • 46
                  Thank you, Nando!
