Labeled wiring harness?
  • diesekte
    • Sep 2013
    • 417
    Anyone have pics of what goes where for S54 e30? The harnesses came to me separately and I've never dealt with an e46 m3, so I have no idea where everything goes. For example, 4 plugs fit the connector for the 3 knock sensors...what order do they go in etc? The plug for the icv and throttle control are the same etc. I opened the black plastic box to reverse the order of the wires since I had no idea where they went anyway, so I can't really just use the length and location to help at this point
  • Andrew325is
    • Jan 2008
    • 1201
    When you mount the harness on the engine you'll find most plugs will just line up with the connector they plug onto, but if you want to label them you'll need to use the wiring diagrams to identify each connector. Carefully peel back the boots on the connectors to expose the wires. Take note of their colors and pin number positions. If you don't want to navigate through BMW's WDS then you can use the 2001 or 2002 Z3 ETM. You can find both of those by searching with Google.
    Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
    • diesekte
      • Sep 2013
      • 417
      I got the intake side figured out - the only questions I have left are the ones I emailed you about what the white plugs do, the one 2 pin connector, and the few power/ground questions.
      Then I need to figure out what to do with the old wiring :/
      • diesekte
        • Sep 2013
        • 417
        If you're like me and get things mixed up, here is what everything is:
        E46 m3 engine wiring harness, counter clockwise from superior screw hole:
        Knock sensor - 2 prong yellow connector; 1 solid black wire
        Water pipe temp sensor - 2 prong green connector with 2 pins; 1 solid brown, 1 brown with purple stripe wire
        Back of oil filter housing - 2 prong green connector with 1 pin; 1 brown with green stripe wire
        ICV - 3 prong green 90 degree connector; red with white stripe and yellow dots, white with yellow stripe, white with green stripe
        Alternator power and 3 prong 2 pin connector; blue wire, green with white stripe
        Oil level sender - 3 prong yellow 90 degree; solid brown, green with brown stripe, white with brown stripe
        Purge valve - 2 prong green connector; red with white stripe and yellow dots, brown with black stripe
        Crank sensor - 3 prong green connector; solid yellow, clear?, solid black wire
        Large rubber connector with injector harness and knock sensor
        Starter wires from alternator
        Throttle position sensor - 3 prong black connector; solid purple, red with green stripe, solid brown
        Throttle actuator - 2 prong green connector; thick solid red, thick solid white
