help! Swap cranks but no start
  • jink0619
    • 808
    It's probably something really simple you forgot or got mixed up. Recheck all your engine connections, cam sensor, cps, tps, etc. For me, it was the wrong fuel pump relay and I didn't have fuel rail connectors clicked into injectors, no start is a fuel or spark problem so look things over you'll get it running.
    Also are ur fuel feed and return lines correct?
    E30love
    • frantic
      • Mar 2008
      • 62
      Yeah I had the same problem, Mine didn't start initially and I had to go over it all again after just leaving it for a week so I wasn't angrily going through it.
      The TB's will not move until the engine starts btw, I wondered the same thing.
      The fact your DME is priming the fuel pump is a positive step. Have you checked for things like if it's sparking? Is there fuel at the rail (guessing so since the pump is priming)
      There is a fuse box on the o2 sensor loom worth checking too..
      • jink0619
        • 808
        With ignition to on position the TBs should open with gas pedal down, mine does it.
        Try spraying some starter fluid see if it will turn over
        E30love
        • diesekte
          • Sep 2013
          • 417
          Yes, fuel feed and return are correct. I tried spraying starting fluid and it didn't work.
          I was able to find my KDCAN cable but the version of INPA I had no longer works after my computer updated to stupid windows 10
          I dug up an older laptop it should work on but can't find a working link...anyone?
          • diesekte
            • Sep 2013
            • 417
            Alright gents....finally found a buddy in possession of a handheld obd2 scanner, and I'm getting a plethora of codes.
            P0121
            P0123
            P0221
            P0335
            P2122
            P2126
            P1637
            Have gotten P1504 and P1508 a time or two as well
            Some are intermittent if I clear them. I looked at the connections for all sensors and unplugged then plugged them back in.
            Car now starts but then promptly fucks off. Runs anywhere from 1 to 5 seconds. If I push the throttle pedal at all it immediately dies.
            Is it more likely that 2 TPS, a crank sensor, and the sensor in the gas pedal are haywire, or the wiring harness that came with my swap is toast.
            If the harness is bad, can I use the harness from an e46 m3 smg car even though I have the 6 speed? I ask because there is one on ebay that looks reasonable but I think it is smg
            • frantic
              • Mar 2008
              • 62
              Yes, the main m3 engine loom should be the same, the only difference is the o2/transmission loom is different and has alot more wiring. I have an SMG one and it works fine.
              • jink0619
                • 808
                Hmmm maybe a bad ICV? Or it's not plugged in correctly?
                E30love
                • diesekte
                  • Sep 2013
                  • 417
                  The icv should be good. It was a known working unit I got with my car in a spare box that for some reason is actually for s54. It is clean and the valve moves freely.
                  I tinkered further and the car will now stay on. However when I push the gas pedal it does absolutely nothing. Are there some pins I can check voltages on on the TPS, gas pedal, or throttle actuator to pinpoint the problem?
                  • jink0619
                    • 808
                    Do u have the pedal plugged in? Lol
                    Again is the throttle actuator plugged in correctly?
                    E30love
                    • diesekte
                      • Sep 2013
                      • 417
                      Yes and yes
                      • jink0619
                        • 808
                        What happens when u pull on the throttle actuator? Does the car rev?
                        E30love
                        • frantic
                          • Mar 2008
                          • 62
                          I would guess you have one of the plugs on the actuator wrong? IIRC there were 2 3 pin plugs, one for a TPS and the other for the actual throttle.
                          • diesekte
                            • Sep 2013
                            • 417
                            Took a look at things....there is one 2 prong sensor for the throttle actuator, and one 3 prong sensor for the tps. Connections are clicked all the way on. No love with the gas pedal and if I manually open the TPS by pulling on the linkage, the car immediately dies
                            It will run indefinitely if I just leave it be but the second it gets even a little bit of the throttle body open (by me doing it manually) it shuts down...like it's leaning out or something
                            • gobuffs
                              • Dec 2004
                              • 513
                              There is a TPS on the throttle and one on the actuator. If they aren't in agreement you will have issues. Where in Texas are you?
                              • diesekte
                                • Sep 2013
                                • 417
                                I will probably try to replace both TPS then. They're only like 50$ and even if they aren't totally shot I guess it's not going to do any harm.
                                I'm in downtown fort worth.
