Did anyone else run into having ECU throw SES light with p0500? My speedometer works fine, and I haven't had any issues with the E30 diff mounted VSS.
Obviously we can't just retrofit the E46 M3 rear wheel sensor (well..easily anyway).
If I clear p0500 I get it back the next time I start the car. My ABS system is functioning perfectly, I can rev all the way to 8k, car drives great otherwise.
I use ultragauge (similar to torque) and when connected to OBDII port it does not seem to receive any speed signal, but does read rpm appropriately.
What am I missing here?
On a (possibly?) related note, I also have p0012 that I can't get rid of. This seems to point to either VANOS solenoid (will get the Beisan one on order), or intake cam position sensor, which I replaced when I rebuilt the engine with a new unit that currently has ~2000 miles on it, so it can't be that
My ECU is from an S54 Z3M I believe. That is what the VIN provided through my OBDII port decodes as
