This isn't the only way to do it but thought I would share my solution for the custom oil drain line you need with Tyler's modified oil pan.
Total cost: $45-55
Instructions on how to cut and assemble the steel braided lines: https://www.pegasusautoracing.com/do...ocID=TECH00027
Things I learned:
Pretty simple.
Parts from Summit:
Finished hose:
Installed:
Total cost: $45-55
- 3 ft of Steel braided -6 AN hose - $15
https://www.summitracing.com/parts/SUM-230603 - -6 AN hose fitting - $5
https://www.summitracing.com/parts/SUM-220690 - -6 AN to 12mmx1.5 banjo fitting - $25
https://www.summitracing.com/parts/EAR-AT807692ERL
Things I learned:
- Cutting this hose sucks. I have a vice and a hacksaw and I did several test cuts before I cut the hose to length (~17 inches). You have to be patient....slow....do it while watching a movie or something... If I had to do it again I might buy the 18 inch hose and just try to make that work.
- The banjo fitting sits a little too right against the valve cover for me with the provided washers. I used one of the stock ones in to space it away a little more.
- The adapter going into the pan is a 12mmx1.5 to -6 AN. If you wanted you could find a hose fitting that goes directly into the 12mm I believe.
Pretty simple.
Parts from Summit:
Finished hose:
Installed:
