Has my DME been previously tuned?
  • BMW_TUNER
    • Jul 2006
    • 1386
    So I have been driving my swapped car a bit over winter and I am noticing that it revs to 8250ish before hitting a hard rev limiter. I have no experience with an untuned S54. Is there a way to tell if I have a tune in the DME. When I had it reflagged for swap I had them leave whatever the redline was set alone. Is it possible that the car that the DME. And from was tuned and that tune is still on the dme?
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
    • 34839
    most likely yes, 8250 is not the stock redline. Unless your tach is wrong..
    • BMW_TUNER
      • Jul 2006
      • 1386
      Cluster was just rebuilt by Bavarian restoration with the M5 coding plug. It only indicates 8k waiting on the new overlay then I can see real rpm but it revs well past 8k. I will try to put a video up on YouTube.
      • mitchlikesbikes
        • Dec 2013
        • 858
        Originally posted by BMW_TUNER
        the irony
        IG: @mitchlikesbikes
        • BMW_TUNER
          • Jul 2006
          • 1386
          Hard to see the tach clearly but it doesn’t hit a soft limiter it hits a hard limiter past 8k about
