The m54b30 E30 build (NL)
  • maxpostma
    • Oct 2018
    • 91
    Originally posted by dude8383
    LOL wow sorry that is literally the first photo. Can you measure the driveshaft for us and report back?
    I have an E36 M3 shaft in stock that I can compare it to.
    Hahaha no problem:), I'ill measure it later this day.
    M54B30 E30 build:
    https://www.r3vlimited.com/board/sho...d.php?t=426585
    • maxpostma
      • Oct 2018
      • 91
      A small update:
      Last weeks we spend way to much time locating the engine in the right position with the e28 3.5 engine mounts. We ended up mounting the engine mounts in the outer subframe holes and removing the little ridge on the mount. This so it was possible to rotate the mount so the engine sits right.
      quite a hassle, but now it sits and fits like it supposed to.
      This resulted in another obstacle:
      The E36 328 drive shaft is 12mm too long, so We will have to shorten that....
      It's never as easy as internet says it is :?
      It was my birthday last week, and I got some E30 goodies :)
      From my girlfriend a Hartge inspired front strut bar:
      WhatsApp Image 2018-12-13 at 09.28.21(2)
      And some other braces and a skidplate to keep the old lady in one piece:
      WhatsApp Image 2018-12-13 at 09.28.21(1)
      Hopefully I'ill have the time to install everything, but I'm very buisy with an robot automation internship, luckily the Christmas break is in sight :)
      M54B30 E30 build:
      • pazi88
        • Sep 2015
        • 584
        You are doing domething wrong or those rotated e28 engine mounts cause that. With e34 m50 engine mounts it's bolt in and the e36 328 drive shaft is 100% right length.
        • maxpostma
          • Oct 2018
          • 91
          It's possible to put the driveshaft in place, but the engine is placed so much forward that an engine sensor hits the radiator (lightly).
          Another possibility is that my supposed e36 328i drive shaft isn't an e36 328i drive shaft.
          I'm just going to measure it, to know for sure.
          M54B30 E30 build:
          • maxpostma
            • Oct 2018
            • 91
            Not really later that day..... but here are the measurements:
            The part from the differential to the center bearing is 97,0 cm or (97/2,54) inch.
            The part from the gearbox to the center bearing is 59,6 cm or (59.6/2,54) inch.
            They do slide into eachother, so to the total length isn't the 2 lengths combined.
            I also noticed that the e30 center bearing barely fits, it's under a bit of stress while installed, is this normal?
            M54B30 E30 build:
            • maxpostma
              • Oct 2018
              • 91
              Another small update:
              Decided to just go for it and trim it (about 15mm), It had to be done because I didn't want to move the engine more forward or buy another drive shaft:
              Luckily the first part of the slidey thingy in the drive shaft is just some kind of plastic which means I didn't remove any of its strength.
              Also replaced the worn out rear bearings:
              All nice and fresh :)
              And made a custom sticker for the new strutbar:
              M54B30 E30 build:
              • hoveringuy
                • Dec 2005
                • 2705
                Now you're just showing-off!
                (I like it!)
                • maxpostma
                  • Oct 2018
                  • 91
                  (I like it!)
                  Hehehe,
                  If you're not a little bit proud of what you're doing, you're probably doing it wrong :)
                  M54B30 E30 build:
                  • sebe20
                    • Aug 2018
                    • 97
                    Had the same issue with the Driveshaft and the sensor hitting the radiator(nothing that a cabletie wouldn't fix tho) but used E24 5-Series engine mounts (70mm with offset) and custom engine brackets.
                    I cut and rewelded the driveshaft exactly at the spot where it's originally fricitionwelded i guess near where the slidy thing is inserted, where it get's wider. make sure to get it balanced, if it's too much unbalanced it could brake the gearboxflange (didn't do that, i just pray the balance isn't too much off)
                    • maxpostma
                      • Oct 2018
                      • 91
                      Luckily I'm not the only one having this issue...
                      I don't think I introduced any inbalance by trimming a tiny piece of in the lathe, just going to try my luck and if there are any vibrations I'ill adress it then.
                      M54B30 E30 build:
                      • maxpostma
                        • Oct 2018
                        • 91
                        Update:
                        An interior update:
                        Didnt do as much as I hoped during the holidays. Mostly because of unvoluntary family stuff..
                        But I did buy myself another e30 as a Christmas present:
                        It's a 324 (turboless) D, bought it because it had a red leather interior. Something I've always wanted after seeing Adam LZ's 335i.
                        I've already swapped my original comfort blue interior over to the tractor which I plan to sell as quickly as possible.
                        [/url]
                        The camera really doesn't do the color justice..
                        The rear bench has a weird sheen to it on the photo, but it looks much better now I cleaned it.
                        [/url]
                        Also got some black doorcards and painted my carpet to match the black&red theme (notmypicture):
                        Did some research about painting carpet, and heared mixed messages about it, decided to try it myself and the result is decent. I think I used too much paint, because in some areas it's a bit cloudy... :(
                        Before:
                        after:
                        And lastly, the cardan shaft is finally in place :bow:
                        M54B30 E30 build:
                        • dude8383
                          • Jan 2005
                          • 10387
                          This should not have been cut like that. This piece locks the shaft halves from being able to move. I'm still surprised you had to change the length of that driveshaft. Maybe the euro cars had different transmission configurations or something.
                          • maxpostma
                            • Oct 2018
                            • 91
                            https://farm5.staticflickr.com/4909/...5164f06d_b.jpg
                            I understand that you're confused, but it really didn't fit before we trimmed the 15mm of the locking nut.
                            Does it really has to be locked into place? because it's already unable to move because it's mounted to the diff, I don't think it's a problem if you have a couple mm's wiggle room.
                            Could be that I'm wrong though..
                            M54B30 E30 build:
                            • maxpostma
                              • Oct 2018
                              • 91
                              I debated about installing an open air filter, it's the most convenient solution but I like the more classy OEM style, ofcourse the stock airbox didn't fit because of the alternator.
                              A litte trim was necessary:
                              Also (almost) finished the back end of the car including the axles, all fresh with new handbrake shoes. Still need to mount the hardlines and bleed the system.
                              M54B30 E30 build:
                              • maxpostma
                                • Oct 2018
                                • 91
                                I'm currently busy with the wiring harness.
                                I think that I've figured out most of the wires.
                                But I've the folllowing questions, which aren't meantioned in the m54 e30 swap thread:
                                -Is it possible to just connect pin 10 from x0004 to the pin 13 of the c101 e30 plug, in stead of using the lime green ms43 relay? (For the fuel pump setup)
                                -is it possible to connect the electric fan signal wire (pin 4 x0004) of the ms43 dme to a pusher fan for the coolant radiator?
                                -Is is possible to make the fuel consumption gauge work? Which wire do you have to connect to c101 pin 8?
                                -is it necessary to use an e30 coolant sensor for the gauge? Or is it also possible to use the ms43 signal and connect this to c101 pin 4?
                                M54B30 E30 build:
