M54 Cruise Control Functionality
  • KI4UJO
    • Jun 2011
    • 640
    I've done some searching but haven't come up with a ton of conclusive information on this topic. As stated in the title, I would like to retain cruise control functionality when going M54 from M52. What I am unsure on is how to get the DME to be happy w/a e30 vehicle speed output. I have a non-ABS car, it is worth noting. Some people seem to just code out VSS, but it is very much necessary for cruise operation. Doing some research, guys doing S54 swaps are using an interface from a Z3 to make the cruise stalk work with the DME, which appears to work for the M54 as well.
    I am doing my own tune and have TunerPro configured. Any input is appreciated!
    IMG_0145 by Jonathan Martin, on Flickr
    • 34834
    It should be pretty much the same as this:
    the main difference is in the DME, where the settings will be different since MS42/MS43 don't have the same parameters as MSS54.
    • KI4UJO
      • Jun 2011
      • 640
      Thank you! That looks as if it will line up w/stuff in tunerpro, will have to look tomorrow
