S54 swap?
  • e30polak
    • 6136
    #136
    Originally posted by M3 euro ltw
    We've developed these side by side, but they're not identical.
    My headers and intake are probably flowing better than Jason's, only because I had invested long ago in a set of euro stock headers, and I'm running temporarily the CF clone of the airbox.
    That having been said, Jason's car would cream mine even if I have a few more horsies, his car has better weight balance, and best of all WAY LESS weight.
    I'm running AC, full stock E36 interior etc....I'd have to guess his car is near to 2200 lb, mine closer to 3200.
    No comparison for the actual cars....And any of you dropping same motor into an E30 will also realize the benefits of less weight.
    Alex.
    Oh sounds good. I'm sure the car still pulls hard for an NA e36!
    Quiet that exhaust down, you need to be able to hear that airbox scream!!! :hitler:
    INSTAGRAM: @UNDR8D_EMPIRE
    • Jean
      • 18228
      #137
      e36 with s54s can be fast!!! look up Vic Sias's autocross e36 car with s54.
      • FredK
        • 14763
        #138
        Yeah, a gutted E36 with a lot of tire can be very fast. Add an S54 and it is even faster.
        • matt
          • 3732
          #139
          Stock e36s are pretty fast. I'd put my stock 328is track car up against most of the swapped cars on here even though it's 3000 lbs.
          • e30polak
            • 6136
            #140
            I'd agree with you. Most of the swapped cars on here don't have very well sorted suspension set-ups. Without dialing it in probably the added weight of the motor over the nose, and the added torque can really turn into a handling disaster. :p
            Then again my swap car was pretty dialed in, and it handled on rails. :nice:
            • Jason89i
              • Sep 2004
              • 875
              #141
              if it handles like its "on rails"..... you're not driving it fast enough. :)
              son, you got to dial in a little more "right foot!" handles on rails...... with an s54...... sheeesh.
              Originally posted by moatilliatta
              DTA ran s54?
              • MarkD
                • Sep 2004
                • 488
                #142
                I will know how to do it soon. It is my current to-do task.
                Soon could be relative. The sun will explode soon, in the grand scheme of the universe.
                I've figured out how to do it, just have not released any kit to do so. My method requires a software update plus either a hardware mod inside the ECU, or a a small circuit outside the ECU.
                URL: www.dsylva-tech.ca
                • MarkD
                  • Sep 2004
                  • 488
                  #143
                  Originally posted by e304me
                  Has anyone thought of just using megasquirt? I think they should be able to control vanos by now?
                  If you had even a slight idea how good the Siemens MSS54 ECU is, you would never suggest that.
                  • 328ijunkie
                    • May 2007
                    • 3961
                    #144
                    Interesting
                    Check Us out on Facebook
                    Full Product Line Tuning
                    • kishg
                      • Sep 2006
                      • 2624
                      #145
                      Originally posted by jason89i
                      if it handles like its "on rails"..... You're not driving it fast enough. :)
                      +1
                      interesting that the s54 swap is becoming more and more common..
                      '12 F30 328i Sport Line
                      '91 SpecE30 #523
                      '00 Ford F-350 Dually Tow Vehicle
                      BMWCCA #360858 NASA #
                      128290
                      • SamE30e
                        • Sep 2007
                        • 4319
                        #146
                        Mike from StanceFactory up here in Toronto had his S54 E36 running for a while, I think last year it was. I heard it was before Burroughs, he was down at H20. He's running all factory wiring and DME's everything works, even sport mode.
                        1985 325e 2.8 Turbo VEMS
                        • Turk
                          • 223
                          #147
                          Nice project!
                          Bear me in mind if you need a way to get the engine running oem style.
                          Cheers
                          Turk
                          Plug and Play S54 & S62 loom/Ecu Kits - Fit you engine to ANY car!!!
                          M50 Sump Baffles
                          High Torque Clutch Kits
                          Custom Flywheels
                          E30 Engine Conversion Kits
                          http://www.bmw.ergen.co.uk
                          LIKE our Facebook page for regular car porn :)
                          http://www.facebook.com/ergenltd
                          • MarkD
                            • Sep 2004
                            • 488
                            #148
                            I worked on the software for an S54 into E36 swap in 2005, who can beat that one?
                            And I have an E30 racecar with s54 swap running in Toronto right now.
                            MarkD
