M54. Let the foolishness begin.
  • bender
    • May 2004
    • 171
    #106
    dude that is so sick. you made some serious progress in a very short period of time, congrats!
    we need some videos!
    600hp beast
    • hoveringuy
      • Dec 2005
      • 2693
      #107
      Dumbass!
      Yeah, that's me.
      Took it for a good 25 mile drive this morning and everything is working GREAT, except the $#@* temp gauge.
      I start trouble-shooting the wiring and get down to the ground path.
      Hello! It's a plastic fitting! Not a good conductor!
      I created a ground to the plug and now the temp guage works perfectly.
      I think I'll leave the zip tie like that, it goes well with driving around with the hood off.
      • lifeiskaos
        • 1709
        #108
        lol nice
        • WillisE30
          • Jan 2007
          • 831
          #109
          Steve, I thought you were crazy when I read the initial post, then I met you and we tried your signal converter on my car and I knew you were nuts. BRAVO!!!
          sigpicFormer professional wrench thrower.
          Current:
          1988 325is S52
          Former:
          2008 Sparkling Graphite M3 Sedan(victim of home ownership)
          1988 M5
          1996 328is
          • I got it, yes!!
            • Feb 2007
            • 206
            #110
            Congrats, Ill have to come take a look at it some day soon.
              • 37828
              #111
              Congrats man, that's badass.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • SpecM
                • Oct 2005
                • 4531
                #112
                that is so cool
                you are my hero
                1989 cirrisblau-metallic 325i
                • hoveringuy
                  • Dec 2005
                  • 2693
                  #113
                  Disa
                  I've been getting more and more details squared-away. I had the heater hoses backwards so I reversed them and now I have cabin heat. The manifold is actually small enough to allow clearance for that!
                  Anyway, I got my RPM activated switch from Summit today and installed it. As background, the DISA valve is a vacuum actuated, electrically activated valve that changes the intake from a low speed optimum setting where resonance packs more air in the cylinders to a high speed setting where it opens up and breaths. It switches at around 3800rpm.
                  I've tried it in both positions, but now that the switch is installed it pulls down low and screams up high.
                  DISA, it's the shizzle!
                  Off to the dyno...
                  • jahnaboi
                    • Oct 2006
                    • 1742
                    #114
                    Dude... could you do my wiring!? LOL. I'm struggling enough just trying to convert my stupid s52 to obd1 considering I don't know where any connections go or how everything is suppoes to mount and what I'm missing because I never had a complete obd1 motor (s/m50) to compare it to what I'm doing as of the moment.
                    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
                    • 2002maniac
                      • 4260
                      #115
                      Congratulations Hoveringuy!
                      • hoveringuy
                        • Dec 2005
                        • 2693
                        #116
                        Dyno time
                        Dynojet. Stock e30 exhaust. DISA switches at 3800 rpm.
                        I'm making close to max torque at 1800rpm?
                        Who can read the graph and tell me when VANOS switches off. ha ha.
                        • matt
                          • 3731
                          #117
                          You're very lean, maybe dangerously so. Are you certain the wideband was calibrated properly? Could something else have thrown it off?
                          • 325Projectz
                            • Jan 2005
                            • 1956
                            #118
                            Originally posted by hoveringuy
                            I learned in the process that the M50 power steering pump IS NOT compatible with the M54. The pulley ends up being offset by about 5/8". I need to order an M54 power steering pump ASAP.
                            have a picture of this?
                            i had a similar problem on my frankenstein s52 with a m54 oil filter housing. i had the m50 power steering pump bracket machined on the back side and now it works perfect. i also tried the m54 power steering pump, and i had more troubles with that. let me know if you a m54 pump.
                            91 m3
                            • hoveringuy
                              • Dec 2005
                              • 2693
                              #119
                              I think the wideband was accurate. It showed good richening at tip in and later he did some driveability checks and the A/F was more normal, although tending to lean.
                              I'm using the Dinan S50 chip. I don't know if the cam profile is causing it to go lean or the 8 extra degrees of VANOS advance. Fuel pressure is around 55 PSI. Should I bump up the pressure?
                              I think this was a good effort for a baseline pull. I need a better exhaust (the stuffing blew out after the first run. It was pretty funny!), I need to get my dual VANOS controller on track, and I need TRM to develop some pimpin' software for this. My goal is 220 wheel hp.
                              • SpecM
                                • Oct 2005
                                • 4531
                                #120
                                I say more fuel pressure is in order
                                but the real culprit is the cam profiles, imo
