m54 bottom end
  • lifeiskaos
    • 1709
    m54 bottom end
    i've been comparing the m54 block and my m52 block, and they look almost 100% identical. knock sensors, crank sensor, mounts, oil filter housing, everything looks like it bolts up the same way. only differences are that there's no freeze plugs in the m54 and there is no obd1 CPS provision (for the crank pulley) on the m54, but i assume the front cover can be transferred from the m52 to the m54. i am also not sure about the oil pump situation.
    my question is, can an m54b30 block be used with an m52 head and an obd1 harness?
  • hoveringuy
    • Dec 2005
    • 2715
    M52 head... no.
    OBD1 harness... yes.
    • lifeiskaos
      • 1709
      why cant the head be used?
      • hoveringuy
        • Dec 2005
        • 2715
        The block and head have completely different cooling passages; they don't match up. The M54 has a "new and improved" cooling system with reverse-flow or something like that. The head is also designed for the M54 intake manifold.
        The front timing cover is also different to match the new head.
        • lifeiskaos
          • 1709
          thats all i wanted to know, thanks. i just hoped the m52 timing cover would fit :( m54 intake manifold doesnt matter because i'd be using an obd1 manifold with m52 head. didnt know about the coolant channels though. oh well
          • SpecM
            • Oct 2005
            • 4531
            you can, however, use the m54 crank/rods/pistons in an m52 block
            1989 cirrisblau-metallic 325i
            • 2002maniac
              • 4260
              lol. It's amazing how many of these motors die from overheating. They really f'd up the cooling system on these motors. I think the t-stat is over 200 degrees too.
              • SpecM
                • Oct 2005
                • 4531
                so true
                • hoveringuy
                  • Dec 2005
                  • 2715
                  The actual cooling system is mostly Ok. The thermostat is an abortion, but that is by design. I've said it before, 90% of what BMW is doing with these motors is to improve emissions and fuel economy. Power if it doesn't interfere with #1 and #2.
                  They intend them to run hotter.
                  I replaced my stock "computer controlled" plastic thermostat with an aftermarket unit from Zionsville and it's been great. These motors usually fail because the higher temperatures generate more cooling pressure and the resevoirs pop. Then, the stupid buffered temp gauge doesn't warn the driver until it's TOO LATE!
                  The M54 block, head and rotating components are great.
                  • GGray
                    • Dec 2008
                    • 26
                    Has anyone tried swappign a single vanos setup onto an M54?
                    I checked on realoem and the cam trays were the same...
                    Gary Gray
                    88 M3 M5x turbo track/race car
                    89 M3 alpine/blk
                    91 M tech vert
                    91 GTi 16V
                    01 325it aka: Wagonator...
                    If you can take it apart you can make it faster....
                    • hoveringuy
                      • Dec 2005
                      • 2715
                      Why would you want to switch, M54 already has a single VANOS.
                      TWO of them!
                      Seriously, the physical VANOS mechanism works slightly differently, it has 20 degrees of advance instead of 12.5, but the solenoid is the same.
                      It works moderately well if you connect it straight to an OBD1 ECU. You could also physically limit the VANOS travel by restricting the piston stroke to make it work better with the 413 ECU or electronically limit it with PWM (my current undertaking).
                      • einstein57
                        • Jun 2007
                        • 10780
                        I might have a lead on a head off an e46 with 60k miles. Some idiot stripped the block and replaced the engine so its pretty much a complete engine with a useless block. PM me an offer and i'll forward it to him.
                        www.gecoils.com
                        • SiGmA_X
                          • Mar 2006
                          • 287
                          You can timesert the block and it should be good to go. FWIW.
                          :wgaf:
                          PNW BMW Crew ///
                          '93 325iS
                          '99 528iT
                          • hoveringuy
                            • Dec 2005
                            • 2715
                            True. I would almost say it's required to Timesert the block. Lots of them are trashed because BMW doesn't endorse the Timeserts.
