325IX Steering rack reseal/rebuild
  • 325ix_STI
    • Aug 2025
    • 8
    Been having a decent size leak from the driver side of my steering rack. Have been trying to find information on resealing it and every site says something different. Some say the normal reseal kit will be fine but I know the racks themselves are different so was looking to see whether or not someone on here has already done it and what they found. Also, I saw another forum where someone said they had a leak that sounds similar to mine and when they took it apart to reseal it was pretty much toast. Not sure if anyone else has dealt with something similar but any info would be appreciated.
  • 82eye
    • Jan 2009
    • 2098
    ix racks are sleeved, regular e30 racks are not. it's often the sleeves that leak, there is no repair other than replacing a rack with a leaking sleeve.
    edit: seal kits should still be available but may have to be ordered from europe direct now. it won't fix a sleeve, if it's only seals leaking it'll do it.
    • litu
      • 847
      Nooo, this sound very bad..When i have small leak. I have e30 steering rack seal kit, but if this is the case, not even bother to do it....
      i have little plan, but it would need money, to make custom metal tube front sub frame where can install like bmw burble tag rack
      https://www.facebook.com/Cry_77_IX-110483784967661
      https://www.instagram.com/cry_77_ix/
      • 325ix_STI
        • Aug 2025
        • 8
        Yah, the only location I'm seeing a leak coming from is that boot on the drivers side which I'm guessing is where the sleeve is that you mentioned. I'm planning on grabbing a rack from a local parts guy but what should I look for to make sure I'm not buying an already messed up one. Obviously going to look for wet areas but is there a way to go about it where I'd be able to notice something before throwing it on the car?
        • litu
          • 847
          my leak from passanger side...So is ix rack serviceable or not
