I know everyone knows what iX weaves look like, just figured I would show another good tire setup.
Stock ix weaves, tires: 195/60r15 conti trucontacts(all season) These tires are great in the summer and still shred in the winter, wear great as well. Perfect for daily IMO.
I know there is a lot of discussion around which size wheels fit the iX. I really want BBS RS3 or RS5 style wheels in 16in. Do you know if these wheels fit the iX? Talking about 1980s style BBS that are popular for the E30 not knockoffs, etc. Anyone have any or done this? Any insight is appreciated, thanks.
You'll need the correct offset, but they'll work. Stock 15" wheels are at ET 41. So if you search for BBS RSs on a 4x100 Honda setup you'll be good to go.
Basically, it depends on the barrels and lips, and what the actual offset of the wheels are. Super low offset wheels (typically fit to RWD E30s) are not going to work.
Generally, depending on tire size of course:
7" wheels - ET25-ET40 (ET25 is pushing it)
7.5" wheels - ET30-ET35
8" wheels - ET30 (+/-2mm or so - they are a tight fit).
9" wheels are never going to fit an ix properly (that is, not stick out 1" past the fenders), unless you do stupid things with "stance" and camber and undersized tires. Thankfully that seems to have finally died out a bit..
That's not how it works. the stock wheel offset is based on stock wheel width, stock tire size, stock suspension, and leaves a ton of room to go wider (I run a 15mm spacer on my stock wheels because otherwise it looks stupid when lowered). Also, if you were to stick with the stock ET41 offset for say, a 8" wide wheel, it wouldn't fit because it would rub the struts and probably rub on the inside in the back as well.
It also depends on the tires, as wider tires obviously have less clearance. FWIW, I've run super wide tires in the past, but I recommend either a 205 or a 225 if it's a street car (realistically, even a 225 is as far as I'd go for a "track" car, not that there are a lot of ix track cars).
I need to do the diligence on my own car to check these out, and I will once I get back from the 'Stan...
What about using different offsets front and rear? Would that allow as wide as an 8.5"? (I might have asked you this once before as well)
My car's been hit lightly in the right rear, and the quarter has been repaired with bondo, but not well. If I replace the quarters with early quarters, that would allow me to punch the rears out a little wider. I could use glass repro M3 fenders in the front to match the width, although that still may work best with a different offset.
maybe, but probably not. The front wheels would have to stick way out, and they will still rub in a lot of places, especially if you're running wide, sticky tires. It would probably work though with M3 fenders.
This captures everything well. Maybe this should be a sticky as to the best sizes for each diameter? Do we have a chart we can put at the beginning of the thread so everyone has a rough idea of what will fit?
Saw these BBS RS knockoffs on ECS, they say they will fit, but it sounds like from Nando's experience they won't?
16" F01 - Set Of Four
16"x8" ET25 4x100/4x114.3 - Silver/Polished Lip
16"x8" ET25 4x100/4x114.3 - Silver/Polished Lip https://www.ecstuning.com/b-f1r-whee...r/f01168s25kt/
Those will not fit at all. There will be too much poke and they will run unless you run a stretched tire.
