ABS Problem
  • ///m3
    • Apr 2006
    • 563
    ABS Problem
    Hi,
    I recently picked up a 89 325ix that has a ABS issue.
    Anyway, when I first start the car, the ABS light is off. After I start driving the ABS light comes on. Can I assume that it's a bad speed sensor?
    I heard that the sensors need to be at 980 - 1000 ohms - is that correct?
    Thanks in advance for any help.
    BMW Headlights ::
  • dubdub
    • Oct 2007
    • 295
    That is roughly correct... I think the issue arrives when you have something waaaay out of spec. (so a 870 reading doesn't mean it is bad).
      • 34839
      it sounds like a bad wheel sensor
      • ///m3
        • Apr 2006
        • 563
        thought so, that is what I will check first.
        Thanks guys
        BMW Headlights ::
        • Bennetts22@aol.com
          • Jun 2006
          • 171
          there is a 2 inch long relay under the knee bolster. its located above the abs unit. it powers the DME and the controls the comunication with the abs computer. 9-10 times this is the problem ( its was on my IX)
          • dubdub
            • Oct 2007
            • 295
            Agree with the above, however, at some point that relay was incorporated into the main abs cpu, so if you spend 2 hours looking for it, fruitlessly, like I did... there may be another reason!
            I had a similar problem as described as above and it went away with the replacement of the abs cpu (with a used one for like $25).
