Screw the "washer mod"...
    Guibo mod! I discovered that the standard guibo form a 325i has the same bolt pattern as the ix front guibo and it is at least 1/2" thicker.
    I tried it out yesterday after swapping out my transfer case and it fits just fine! You just need slightly longer bolts. I used BMW part numbers 26111204215 M10x42 and 26111225054 M10x50
    The only issue is that the bolt heads on the guibo will interfere with a bolt that holds the bellhousing to the oil pan. I removed it and cut it to eliminate the interference.
    i forgot to measure the difference between the two guibos so I'll update this thread after i do that.
    nice :)
    the best of both worlds - spacer/thicker guibo & longer driveshaft
      Nice find! I think this is a better idea than washers. Stronger and safer.
        sweeeeeeeeet
        88 325 IX DiamantSchwarz - TOURING - waiting...
        89 325 IX AlpinWeiß - Gone
        88 325 IX DiamantSchwarz - Parted
        89 325 IX RoyalBlau - Parted
        88 325 IX RoyalBlau - Gone
          Good to know, does the metal alignment piece still work with it?? May get the parts myself and check it out!
          S52 iX conversion --> http://e30tech.com/forum/showthread.php?t=78938 :D
            Any idea if this will work on both standard and autos?
              the driveshafts on both are the same so yes
