I want to flush my transfer case/tranny/diff fluids...
  • audiquattrot
    • May 2008
    • 3836
    What would you guys recommend for each?
    My iX didn't come with any manuals, so I wasn't sure how many quarts everything takes, and what the recommended fluids to be used were.
    I'm guessing ATF for the tranny? and gear oil for the transfer case & rear diff?
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • smcdermott326
    • Jan 2008
    • 84
    iX Driveline oil change.
    > Front differential:
    > Spec: 90W GL-5
    > capacity: 0.75 qt
    > drain/fill plugs: internal (Allen) head, Size ?
    > commonly used after market oil: Redline Synthetic 75W90
    > Rear differential:
    > Spec: 90W GL-5
    > capacity: 1.8 qt
    > Manual Transmission:
    > Spec: 80W GL-4
    > capacity: 1.4 qt
    > drain/fill plugs: internal (Allen) head, Size 17MM
    > commonly used after market oil: Redline Synthetic MTL (manual
    transmission lubricant)
    >> > AT: 3.2 US quarts/3 liters
    > Transfer case:
    > Spec: ATF
    > capacity: 0.6 qt
    > commonly used after market oil: Redline Synthetic ATF
    • tirefryer
      • 106
      For the transfer case, the recommendation is Redline Synthetic ATF: D6 or D4? I am assuming D4, but can someone verify this.
      Thanks.
      • ScottJ
        • Feb 2011
        • 3
        Redline ATF D4
        Redline ATF D4 is what you use. D6 is a different spec.
        • tirefryer
          • 106
          Thanks!
          • ZM Blue Devil
            • Dec 2006
            • 13836
            also have new crush washers ready
            Levent
            %20levent@gutenparts.com
            Ladies:
            • tirefryer
              • 106
              Hadn't thought of that... can I get the size of the crush washers from RealOEM?
                • 34844
                there aren't crush washers on any of the drivetrain, only the oil pan.
                • tirefryer
                  • 106
                  I like this much better :)
                  Thanks nando!
                  Any recommendations on where to order Redline products from...Jegs? Summit? ...?
                  • z122643
                    • Aug 2011
                    • 286
                    There are crush rings on the transfer case, Front differential, and rear differential.
                    [/SIGPIC]"we are so totally screwed!"
                      • 34844
                      not on the fill plugs. they're pipe-thread fittings. I've done all 3 of those like 10 times myself. :)
                      • z122643
                        • Aug 2011
                        • 286
                        Interesting, only my fill on my xcase was pipe-threaded.
                        • canadiankid
                          • Mar 2012
                          • 262
                          Anyone know crush washer sizes just in case?
                          • z122643
                            • Aug 2011
                            • 286
                            Xcase drain plug washer size is 18x22 BMW#07119963308
                            • canadiankid
                              • Mar 2012
                              • 262
                              So go to the dealer to get it or is there a standard size?
