Question for people running 205/60r15 tires
  • dark89e30
    • 263
    I have an iX and am looking into tire options for my stock 15" weaves. I've read that a few of you are running 205/60r15s and I'm currently looking at Michelin Exalto A/S. Is there anyone running this size that would mind sharing a pic or two so I could see how they fill out the wheel wells? Also, does anyone know if this size will fit in the spare tire well? Thanks!
  • dark89e30
    • 263
    Anyone?
    • e21
      • 7
      I run that size for snow tires in the winter. they rub the front plastic liner slightly at full lock but I also run spacers, 12.5 in the front I think and 15 in the rear. in the summer I run the same spacers on stock weaves with 225/50/15, very slight roll in the rear. 205/60/16 will fit in the well. I'll take pictures if I get a chance in the next few days.
      • JuanPabloBongto
        • Mar 2008
        • 375
        I run 205/65/r15 for winter tires, on stock 15" iX basketweaves. They must be the largest tire that will fit a stock setup.
        Clearance at the front is fine, with only about 1/4" between the spring perch at the top, and about the same on the inside.. 1/4" from inner sidewall to the strut housing.
        There is so little clearance to the rear that I doubt my mudflaps will fit.
        They do rub the plastic fender lining on sharp turns. And I don't care.
        Sorry, don't have any pics, just wanted to let you know that it is a valid size option.
        edit: and yes, i'm sure it would fit in the wheel well.
        • packratbimmer
          • Dec 2009
          • 1334
          I run 205/60/15 with stock springs and love them. They hold up to pot holes well! Careful about speed ratings on that size-they are all over the place.
          • Lemuis
            • Jul 2008
            • 9
            I run this size in Michelins Pilots that won't wear out no matter what I do. No issues what so ever. Stock suspension. And they fit perfectly in the spare tire well.
            http://www.flickr.com/photos/20494156@N04/5177345713
            http://www.flickr.com/photos/20494156@N04/5177947356
            • boosted_E30
              • Dec 2010
              • 173
              I run 205/50/15's on mine, lowered on H&R sports
