Removing crank bolt
  • A Sucked Orange
    • 707
    Removing crank bolt
    Currently trying to remove crank bolt.
    Car is currently on jackstands w/out front axles or control arms.
    Put car in gear w/ e-brake and tried to loosen crank bolt, but the engine just turns along with the front driveshaft. Is there ahy way I can get around buying the crank tool?
  • KenC
    King of Kegstands
    • 14396
    Put the front back on and lower it down.
    Originally posted by Gruelius
    • KenC
      King of Kegstands
      • 14396
      MAYBE a huge impact gun.
      • A Sucked Orange
        • 707
        Oh I forgot, control arms are also removed.
        Sure wish I'd done this before :D
        • Chruby99
          • May 2011
          • 262
          ha
          that is how mine is sitting now. Just sent the half shafts to get rebuilt.
          Hit it with an impact
            • 34844
            I put a pipe wrench on the hub to hold the crank and went to town with a breaker bar and 3 foot cheater pipe.
            • A Sucked Orange
              • 707
              Figured it out.
              For anyone who may read this in the future...
              Put it in 5th gear w/ e-brake.
              I locked the front driveshaft through the joint with a 1/4" extension about 6" long right where it goes in to the diff. Worked like a charm.
              Big cheater bar needed.
