Happened this morning on my way to work. Was cruising around 60-65mph, under a little acceleration, the car started vibrating like crazy. Almost like i was driving on rumble strips. I let off the throttle, and it slowly went away, and came back. Anyone know what the potential problem could be?
I'm getting a pretty violant vibration @ certain speeds on the hway...
www.instagram.com/snwmble
#snwmble
Current:
'05 BMW M3 - Silver Grey/Imola Red
'90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
'15 Mini Countryman - Blazing Red/Carbon Black
Past:
'01 Audi Allroad - Light Silver/Platinum Saber Black
'88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
'01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
'90 BMW 325i - Schwarz/Tan sport *Sold*
'89 BMW 325ix - Diamond Schwarz/Black sport *Sold*Tags: None
Originally posted by 325ix View PostI think it may be the lower u joint in the steering. Mine does this sometimes too. Is it the steering wheel that is vibrating uncontrollably?www.instagram.com/snwmble
#snwmble
Current:
Past:
First thing I'd check is the guibo. There are other possibilities that are less happy.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
Originally posted by nrubenstein View PostFirst thing I'd check is the guibo. There are other possibilities that are less happy.www.instagram.com/snwmble
#snwmble
Current:
Past:
Originally posted by audiquattrot View Postwould i be able to tell by looking at the guibo? i would assume it would look shredded?2006 GMC Sierra 2500HD 4WD LBZ/Allison
Originally posted by A Sucked Orange View PostSome times if your steering components have worn out joints the wheels will wobble at certain speeds. You might check and see if anything has play in it.
Originally posted by nrubenstein View PostYou're looking for cracks and such.
cool thanks. i'll check it out.www.instagram.com/snwmble
#snwmble
Current:
Past:
I would say either guibo or driveshaft. I've got the same thing on my '89 ix and am in the process of removing the exhaust and driveshaft. I've also got to take the transfer case out and put in a new VC, so it's gonna be down for a while."I think we consider too much the good luck of the early bird and not enough the bad luck of the early worm."
-Franklin D. Roosevelt
so i got underneath, and the guibo is fine, no cracks or shreddings. I removed the plastic cover that covered the driveshaft, and saw this. Are the splines supposed to sit out like this?
#snwmble
Current:
Past:
Yeah, the splines should stick out about that far. It is most likely your rear driveshaft, guibo, or the rubber mount from the transfer case to the frame. Or a combination of the three."I think we consider too much the good luck of the early bird and not enough the bad luck of the early worm."
