Ix engine removal
  • Chevy2g3
    • Apr 2011
    • 59
    Ix engine removal
    Does anyone know how to take off the front axles on the ix? It's the only thing keeping the engine in the bay?
    • 34839
    Pull.
    The mounts hold it in too? Not sure what you meant.
    • Chevy2g3
      • Apr 2011
      • 59
      Well it looks like they run through the oil pan. I guess I have to remove the axles.
        • 34839
        yes. they pass through. just pull them out, they're clipped into the diff.
        the easiest way is probably to drop the whole subframe/engine/trans underneath the car instead of pulling it from the top.
        • Chevy2g3
          • Apr 2011
          • 59
          Just finished! It was much easier. Thanks bro!
          • Chruby99
            • May 2011
            • 262
            Any pointers on this. Looks like unbolt ing the alumnium sub frame and the brace/yolk at the transfer case. Minimal connections. Pull the fan clutch. What do you suggest for supporting the drive system
