Torque specs - IX specific
  • Morrison
    • 430
    Does anyone know the torque specs for the bolts that connect the transfer case support bracket to the body and the bolt that connects to the rubber transfer case bushing?
    "I think we consider too much the good luck of the early bird and not enough the bad luck of the early worm."
    -Franklin D. Roosevelt
    • 34844
    I don't know off the top of my head but you can usually go by the bolt size. I'd say 60ft/lbs will do, but I usually just go "good and tight" and call it a day (never had one back out?).
    • supernaughtIX
      • Apr 2007
      • 260
      good n tight for me too, and when in doubt, add some loctite.
      88 325 IX DiamantSchwarz - TOURING - waiting...
      89 325 IX AlpinWeiß - Gone
      88 325 IX DiamantSchwarz - Parted
      89 325 IX RoyalBlau - Parted
      88 325 IX RoyalBlau - Gone
      • z122643
        • Aug 2011
        • 286
        Are you talking about these bolts?
        [/SIGPIC]"we are so totally screwed!"
        • Morrison
          • 430
          Yeah, that's them. I ended up just sort of guessing what seemed reasonable and torqued the big one to 60 ft-lbs and the outer short ones to 40 ft-lbs.
            • 34844
            don't overtorque the ones from the brace to the body. the caged nuts will start to pull out of the car. ask me how I know this.. :(
