e30 block differences
  • jrabbit
    • Apr 2006
    • 15
    curious if 325i blocks will interchange, have a stroker bottom end with MM pistons, would like to put in my ix. I know about oil pump differences, curious about motor mount bracket mounting and any internal differences.
    thanks,
    JJ
    • 34837
    the ix uses a different oil pump and intermediate shaft gear. you'll have to remove the oil pressure regulator from the RWD block. there's nowhere to put a dipstick for the ix.
    best bet - remove the internals from your RWD block, put them in an ix block.
    • jrabbit
      • Apr 2006
      • 15
      thanks
      • MikeDE
        • 1873
        Do a 2.7 while you're at it.
        -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
        • tirefryer
          • 106
          so in other words, I cannot just yank my motor out of my 89 325ix and replace it with another M20 motor (after swapping out the ix specific oil pan)?
          • Ceeker
            • Sep 2009
            • 2821
            the dipstick hole is in a different location on a reg m20 vs m20 IX. you would have to plug the M20 hole and drill a new one for the IX dipstick location. it is possible, but maybe easier just to swap the internals over to the IX block.
