5 lug adapters ok on a e30 ix??
  • spiDmang
    • 3941
    Hey iX gurus,
    I'm curious about a wheel set up for a potential e30 iX I might be acquiring soon...
    So for my question, I have 5 lug adapters that are 20mm in thickness. The wheels are e38 style 5s that are et23...
    Would this wheel set up be safe to run with the AWD system? I know the ix is super sensitive with this kind of stuff....
    Thanks In advance!!
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
  • Eric
    • 5139
    no, that's way way to low of an offset. To run those adapters you need to be running et40 or more on an 8 inch wheel.
    Your best bet is to sell the adapters and put that cash towards a shop redrilling the wheels to 4x100. et23 on 16x8 is still pushing it, but can be done with the correct tires.
      • 34839
      an 8" rim with a 23mm offset is too low already for an ix. adapters/spacers are out of the question. it's not going to fit, no matter how you cut it. well, maybe if you ran a 185 tire or something. you need an offset around ET30-35 for an 8" wheel and you'd still need to get agressive with the rear fender trim for that, or run pizza cutter tires.
      • spiDmang
        • 3941
        I'm not concerned about if they will fit under the fenders. I'm concerned if that offset will affect the AWD system at all? The wheel setup I have it's staggered or anything.
          • 34839
          it shouldn't affect the AWD, but they're going to stick out past the fenders about 1". the front will be worse than the rear. you probably won't be able to turn the wheels full lock either.
          • spiDmang
            • 3941
            Thanks for the info nando! Like I said, all I'm concerned about is not affecting the AWD with this setup. This is probably a temp situation until I can find some stock iX basketweaves..
            • 619E30
              • 1753
              Sell adapters to me :)
              Originally posted by audiquattrot
              bimmers b4 b*tches....remember that.
              1990 Alpinweiss 325i - secret 500whp build
              2000 Audi S4 B5 Laser Red
              1990 Nissan 240sx - Drift Missile
              2006 CBR600RR
              • spiDmang
                • 3941
                If I can find some stock ix weaves I'll consider it :)
                  • 34839
                  There are tons of e30 wheels that fit directly
                  • Wishno87
                    • 6025
                    JJe30 has ix weaves.
                    • spiDmang
                      • 3941
                      Is he in the PNW?
                      • flyboyx
                        • 8371
                        staggered wheels will screw up the ix awd system. do not run them different diameters wheels will cause the vc to spin causing heat. this will in turn melt the seals causing the atf in the case to mix with the silicone in the vc. bad news....
                        standard ix wheels are et41. standard e30 wheels are et25. the hubs already stick out 16 mm further than a standard e30 with the same fenders. adding 25mm adapters will put you at et66. this is no bueno under any circumstances because the rear tires will fall outside the fender wells by almost an inch.
                        Gigitty Gigitty!!!!
                        • Wishno87
                          • 6025
                          Originally posted by spiDmang
                          Is he in the PNW?
                          Ya in vancouver.
                          • Eric
                            • 5139
                            your math is backwards
                            et25 + 25mm adapters = ET0
