Bad atf leak
  • mkcman17
    • Jul 2010
    • 8240
    Bad atf leak
    my auto ix is hemorrhaging red atf while driving. Once stopped, the car is dry, but after warming up a little an almost steady drip comes down from what seems to be between the rear of the trans and front of the transfer case. I'm new to ix's, is this a common leak?
    apologies in advance if I haven't searched this forum enough yet.
    1989 LN106 Hilux / 3.0TD SFA
    1974 2002tii / stock
    2002 IS300 / 5spd LSD
    • 34827
    since there's not really enough fluid in the transfercase to leak like that, the output seal on your trans is shot.
    • mkcman17
      • Jul 2010
      • 8240
      Yeah, the trans fluid level drops absurdly fast. I assume the tcase need to be dropped to change the seal...
      a few pictures (first time getting under the car)
      front driveshaft
      leaks seem to be from more than one spot after a 20 mile drive...all red atf.
      trans->tc
        • 34827
        yes, the T-case must be removed.
        your front dust cover is shot (front driveshaft). that is not good, since it protects the seals and splines from water/dirt. it's a cheap part, so best to replace it while you're there, and regrease the splines.
        • mkcman17
          • Jul 2010
          • 8240
          alright, began the teardown today. the front driveshaft splines aren't stripped on either end, although there is definite play visible when alternating directions of torque. with the trans tilted down, red ATF seeps out consistently. the rear driveshaft has clearly been the source of vibration, as the output flange seems to have backed out of the TC and leaves lots of wiggle/shake room. also the TC/trans support bracket bushing is pretty much shot. any tips for removing the rear DS? with the output flange backed out, there little to no slack to drop the DS. i tried unscrewing the slip yoke, but that doesn't seems to be significant in creating slack...
          • Ether-D
            • Sep 2011
            • 2838
            I just had to take my rear drive shaft out...
            On mine, I just took a big flat screwdriver and pried it backward from where the guibo was attached. I was surprised at how easily it slipped back. It slipped back about 1 1/2". I didn't have to loosen the collar at the back.
            Originally posted by Andy.B
            I was born on 3/25…
              • 34827
              once you've loosened the collar nut you push the shaft back. the slip yoke will collapse giving you plenty of room to get the shaft out of your way - you don't need to remove it from the diff or the car (unless you need to replace it).
              • mkcman17
                • Jul 2010
                • 8240
                Thanks guys. Still trying to figure out why the rear flange backed out of the TC...looks like the DS pulled it through.
                • flyboyx
                  • 8371
                  this
                  Gigitty Gigitty!!!!
                  • mkcman17
                    • Jul 2010
                    • 8240
                    alright, i know some if not most of you have been helping me on e30t, but an update!
                    i've decided to go manual swap, trans and new clutch should be arriving today and manual transfercase is being shipped out today as well. old trans/tc/flywheel are out and the new pedal assembly is in. the only snag is that i thought i had a spare single mass flywheel in the garage but i don't....so i'll need to go source one out in the meantime. still need to change the rear main seal and trans carrier bushing in the meantime. changed the timing belt yesterday and am cleaning the 'new' m50 injectors tonight.
