Newly rebuilt transfer case leaking tranny fluid?
  • audiquattrot
    • May 2008
    • 3836
    Had a place rebuild my transfer case, refilled it w/ tranny fluid (which seemed to have only taken 1/2 qt of fluid.....put all new seals & new breather cap.
    Been noticing since then, that the transfer case is coated in tranny fluid. Its tough to figure where the leak is coming from, but I'm hoping we filled it too much, and is just escaping from the breather valve?
    Can anyone shed some light on where else it could be coming from?
    THanks
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • jute91
    • Nov 2011
    • 581
    did you install seals on correct level? here's my friend page, "how to rebuilt transfer box" http://juubi.hlan.net/index.php?page...x/transfercase
    Also found on Facebook - Juuso Tero, Tampere
    https://www.facebook.com/JuusosGarage
      • 34839
      the most likely seals to leak are the front output shaft seals. there are two and they need to be put in in a specific orientation. they face each other, essentially. 1/2 quart sounds about right. it's not really possible to overfill it..
      • Chruby99
        • May 2011
        • 262
        How big of an undertaking is this rebuild. I am pulling the whole engine/trans/tcase and I want to replace all the leaky seals. It does not look to dificult
        • z122643
          • Aug 2011
          • 286
          Is isn't if you've done it before. Otherwise... it's a challenge. I was fortunate to have the factory manual.
          [/SIGPIC]"we are so totally screwed!"
          • 330i ZHP
            • 264
            I now (maybe I did before - but didnt see evidence) have a leak on my transfer case. It looks like it is coming from the front shaft connection.
            I replaced ALL the fluids over the past week (I did the diffs, trans and transfer case last night and I filled the trans and transfer case this AM). I noticed fresh clean atf leaking.
            Could cleaning everything (years of minor grime mixed with fluid residue and old cosmolean) and filling with new fluid cause (or activate) the leak?
            I did not remove the shaft
            Also, is the head gasket a common oil leak source on the engine? I have a flow of oil coming from the right front - seems to be coming from the head/block.
