Remove Drive Shaft - 325ix
  • e30forlife
    • Mar 2012
    • 583
    In order to remove the drive shaft do I have to to drop the rear subframe?
    Really hard to get to the bolts to the diff.
    91 318 s52 Swap
    -m50 manifold
    -headers
    -zf320
    -3.25lsd
    -KaMotors Intake
    It is not necessary to drop the rear subframe to get the drive shaft off. Long box end wrenches will get the nuts off.
    • e30forlife
      • Mar 2012
      • 583
      Flex dic bolts are off.
      I loosed up the big nut also.
      The back nuts near the diff are off also.
      Why wont this damn thing come down? Im able to wiggle it and move it forward but not enough.
      What do I do next?
      91 318 s52 Swap
      -m50 manifold
      -headers
      -zf320
      -3.25lsd
      -KaMotors Intake
      • e30forlife
        • Mar 2012
        • 583
        Anybody?
        91 318 s52 Swap
        -m50 manifold
        -headers
        -zf320
        -3.25lsd
        -KaMotors Intake
          • 34839
          You need to collapse the shaft. loosen the slip yoke at the rear and push it ttowards the diff.
          • e30forlife
            • Mar 2012
            • 583
            Ive done all of this...
            Ive loosen the big nut.. Taken all of the nuts off the rear diff. But can get the actual bolts to come out. My guess because of weight from the shaft.
            But my goal is to push the shaft towards the diff and the front of the shaft should come out?
            91 318 s52 Swap
            -m50 manifold
            -headers
            -zf320
            -3.25lsd
            -KaMotors Intake
              Once you collapse the drive shaft (after loosening the collar nut) either end of the drive shaft can be dropped. The splines may be stuck and liberal use of PBlaster or Kroil and a day or to for that to penetrate can help. If you are still stuck, dismount the CSB and pull down at the center u-joint. That should extend the drive shaft some. Spray more penetrating oil on the splines and push up. Repeat until you can collapse the drive shaft.
              If the drive shaft is truly seized , disconnect the half shafts and drop the diff & drive shaft. Then send the drive shaft off to be rebuilt.
              • e30forlife
                • Mar 2012
                • 583
                This is an IX model. I dont think I have an CSB.
                91 318 s52 Swap
                -m50 manifold
                -headers
                -zf320
                -3.25lsd
                -KaMotors Intake
                  • 34839
                  Ix = no csb
                  • Zasz
                    • 1030
                    ^Wat. GL, iXs are weird.
                    ///Z
                    1988 BMW 325 Super Eta - Elsa
                    "i"CONVERSIONWARchip&3.0MAF3.73LSDBBSRSsSMILIES"is"SPOILER+LIPHOUNDSTOOTHSHORTSHIFTERPLASTICBUMPERCONVERSIONEtc.
                    Sell Me Your SCHWARZ FENDERS!
                    ^ Nothing you post makes any sense.
                    • e30forlife
                      • Mar 2012
                      • 583
                      Yeah tell me about it. This is the first car ive ever worked on too...
                      Was about to get the driveshaft to come off last night. A crow bar is the magicstick!
                      91 318 s52 Swap
                      -m50 manifold
                      -headers
                      -zf320
                      -3.25lsd
                      -KaMotors Intake
                      • Chruby99
                        • May 2011
                        • 262
                        You should be able to collapse it enough to clear the sub frame and drop out. My biggest obsticle was sliding it out between the floor board and exhaust(i did not remove the exhaust, would have made it way easier)
                        • cabriodster87
                          • Jan 2011
                          • 1042
                          There you go, now you've got it.
                          Reich und Roll!
                          • BrassDrummer
                            • Feb 2012
                            • 68
                            One of the most useful tools in my toolbox. As crude as it is and as it sounds, that shit makes me money.
