Hello there everyone. I just got back from my local mechanic and am the recipient of a $2,900 parts/labor estimate that has directed me to seek your counsel regarding my suspension set up and how much (if any) of the labor costs I can remove by doing some work myself.
First a little background on the car in question. I have a 88 ix with 179,xxx on the clock. A lot of the bushings and minor suspension pieces are reasonably new on the car, but the main working parts of the rig are mostly original (I purchased the car at 135,xxx) and are pretty worn. The shop suggests new shocks, front control arms, and a couple other minor pieces. I should note that the quote above covers OEM parts.
My questions are thus: One, given the fact that I'm set to swap out my entire suspension and I'm inclined to upgrade rather than replace, what would you recommend as a good suspension set up for a car that will see a 50/50 split of track and street duty? This isn't going to be a full race car, nor will it be a daily driver, but something that is a little compliant for Bay Area roads would be good. Also, full coilovers aren't really my thing as I don't feel a need for constant height adjustment... My mechanic recommended the H&R cup kit if not going OEM, but I don't see the full kit available for the ix.
Side note (question 1a), the car came with Momo aftermarkets (15x7 I think, no clue on offset)...very 80s...and my mechanic was recommending changing these because they were wearing out the suspension and would be hard to align. True or is he just avoiding work?
And, two, what of this might be DIY to save me some cashola? I've read through some of EyExR's posts and maybe it's the level of detail he includes (h/t to the beer pictures) but I'm concerned that this work may be above my pay grade. I change my own oil, have replacee a EGFR sensor and alternator in an S-10, and helped swap a clutch in a '81 VW Rabbit for reference. I don't have a garage or a lot of specialized tools, but I don't necessarily see these as rate limiting steps.
OK, that was really long, and if you've read to this point, go ahead and give yourself a pat on the back. If you feel inclined to go one step further and reply with helpful advice, make that two pats.
Thanks in advance - jg
