Wheel hop in tight turn, ix issue?
  • Earendil
    • 1662
    Posting this question for my Dad, who has an ix.
    He is experiencing wheel hop on dry pavement when in a tight (wheel lock) turn. His definition of wheel hop is "What a suburban wheels like when you forget to take it out of 4 wheel drive".
    AFAIK Viscous diffs fail in an open position, correct? Could one have failed in a "more resistance" manner, such that it isn't allowing proper slip when in a tight turn? I'll take a look at the car next week, any ideas on what to look for or test to narrow this down?
    Thanks guys :)
    1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
    2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
    I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
  • flyboyx
    • 8371
    i doubt one could fail in the locked position. generally, the simply overheat, the seals melt, the silicone in the vc mixes with the atf. that is pretty much it. are you sure his is bad?
    both my ix's have good vc's. when i take a tight corner at slow speeds such as in a parking lot, i feel a slight binding whining noise which simply means the vc is doing its job.
    Gigitty Gigitty!!!!
    • Chruby99
      • May 2011
      • 262
      Bad cv joint? Or poor alignment
      • dashboardmonkey
        FUCK YOUR WAFFLES
        • Jun 2008
        • 6158
        cv joint would be my guess
        -Andy
          • 34839
          I second the bad CV joint.
          I've never noticed this. could alignment be an issue? even if it did bind slightly, I don't think it would feel like a 4WD with the transfercase left locked.
          I think the only way a VC could fail locked is if the VC got so hot that the plates inside physically welded themselves together.
          • Earendil
            • 1662
            And while my Dad is a very aggressive driver, he hasn't done anything like track the car, so I doubt that is it.
            I hadn't considered the CV joints, but that's a decent guess. The car has over 300K on it, so the CV joints might be due for a refresh ;)
