New set has arrived! Front shaft uppgrade *Finland-Fix*
  • TehRaydarlover
    • Mar 2013
    • 544
    #76
    Originally posted by BikeBuddha
    Hey guys,
    I'm new here to the forum and a new IX owner as well. I have a 1989 ix w/ 100k miles and the front driveshaft is worn. I'm interested in the extender here, which is now on eBay, but I'm wondering (as a novice mechanic) whether I will have to replace the transfer case as well given that the driveshaft is worn, or whether this longer driveshaft will catch enough of the transfer case teeth to avoid having to buy a new one (at least for now). Any advice or thoughts we be appreciated. Thanks.
    Are the splines in the transfer case stripped? I feel like the splines in the transfer case would be made of a harder material than the splines in the drive shaft, cheaper to replace the shaft than the transfer case. But I could be wrong. Regardless if you get the extended splines I believe in increases the touching area from 18mm to 50mm so if the splines in your T-case are stripped you would still have 32mm of touching area left. Probably cheaper and easier to shim the drive shaft for now and get the upgrade than replace the T-case. Not sure what T-cases are going going for.
    Build Thread
    Rear Diff Rebuild
    Rebuildable Viscous Coupling
    Transfer Case Rebuild
    "Life is simpler with 12 valves"
    • BikeBuddha
      • Sep 2013
      • 3
      #77
      Yes, the splines in the T-Case are worn a bit as well, unfortunately, but only up to the point that the driveshaft extends into the case. My thought was that the extra bite on the extension would compensate for the worn bits, but I'm not sure...
      • jute91
        • Nov 2011
        • 581
        #78
        that would work well i guess..
        Also found on Facebook - Juuso Tero, Tampere
        https://www.facebook.com/JuusosGarage
        • berlow94
          • Jan 2013
          • 1063
          #79
          Could you please PM me details about buying one?
          Interested.
          Thanks!
          The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
          • TehRaydarlover
            • Mar 2013
            • 544
            #80
            Finally got around to working on Juuso's spline upgrade.
            Sand blasted the stripped drive shaft I got from audiquattrot, thanks again! Comparing the new head with the old shaft the weld should be in the same spot as the original. That being said make sure you cut the head off after the weld otherwise you will be left with a lip on the inside from the original weld and you'll be stuck filling it off. I used a press to get it on all the way.
            Just need to weld it and get it painted and it should be ready to go! Nice work Juuso!:D
            Build Thread
            Rear Diff Rebuild
            • jute91
              • Nov 2011
              • 581
              #81
              Thanks. And also thank you for good explaining and pics
              • Bmjpv
                • Mar 2007
                • 561
                #82
                shaft upgrade
                I got my shaft welded up and installed . I've dropped the engine/trans setup out the bottom. Rebuilt transfer case ,rebuilt rear d/shaft,upgraded front d/shaft, sand blasted both front struts ,treated with POR 15 ,new tie rods . Rebuilt cyl head with new cam,rockers/shafts and valve job. Installed new AC condenser/dryer and freeze 12 service,new fan clutch and new aux fan. New rubber brake lines all around wth new rotors/pads. And finish up with major service with all oil seals and syn fluids as needed. Joe
                  • 34847
                  #83
                  still have some for sale?
                  nvm - I see them on ebay
                  • jute91
                    • Nov 2011
                    • 581
                    #84
                    hah - yes I still have them :) and they can be found from ebay
                    -juuso
                      • 34847
                      #85
                      Yeah, now that i see how they are made,i want two. Haha.
                      I thought there would be a problem with the thicker x5 flex disc, but then i realized you could just cut the shaft shorter.
                      • z122643
                        • Aug 2011
                        • 286
                        #86
                        $190.00 argh.....
                        [/SIGPIC]"we are so totally screwed!"
                        • litu
                          • 849
                          #87
                          That's cheap, when you consider what metal it is used and you think this, where it will be used and what it is meant to be, there may be value for money
                          https://www.facebook.com/Cry_77_IX-110483784967661
                          https://www.instagram.com/cry_77_ix/
                          • jute91
                            • Nov 2011
                            • 581
                            #88
                            That's correct ;)
                            • audiquattrot
                              • May 2008
                              • 3836
                              #89
                              no prob buddy ;) Awesome work on fitting it!
                              and damn now looking at the comparisons you posted, i like the way these shaft inserts are made! good job jute, I have a spare stripped shaft myself, and might do this down the road to have as a spare.
                              www.instagram.com/snwmble
                              #snwmble
                              Current:
                              '05 BMW M3 - Silver Grey/Imola Red
                              '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
                              '15 Mini Countryman - Blazing Red/Carbon Black
                              Past:
                              '01 Audi Allroad - Light Silver/Platinum Saber Black
                              '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
                              '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
                              '90 BMW 325i - Schwarz/Tan sport *Sold*
                              '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
                              • Yogiyost
                                • 20
                                #90
                                any left? If so, I want one! Let me know haw to get you paid-- Thanks, Bob
