Ix m20 weight
  • mclawrence
    • Jul 2012
    • 50
    Ix m20 weight
    anyone have a ballpark weight for a complete m20 with m/t and t/c attached ?
  • jute91
    • Nov 2011
    • 581
    all i found this far
    Also found on Facebook - Juuso Tero, Tampere
    https://www.facebook.com/JuusosGarage
      • 34839
      the transfercase is about 65lbs, the front diff is about 40.
      the ix also has an aluminum subframe and other pieces that are steel on standard E30s.
      I believe the engine is in a slightly different position - closer to the firewall. I haven't been able to confirm this though.
      the other ~30-40lbs is from the front strut housings and driveshafts.
      • mclawrence
        • Jul 2012
        • 50
        i finally found the fully dressed m20 weight at 360lb so less then 550lbs to lift as one peice
        thanks
        • z122643
          • Aug 2011
          • 286
          I believe you are correct, because I took the engine out of my iX for a rebuild and it seemed a lot tighter then the one I took out of a 325i (1989)
          [/SIGPIC]"we are so totally screwed!"
          • gw ix
            • 158
            The ix engine I have forsale as it sits with the exhaust & intake manifolds attached weighs 347 lbs.
            • jute91
              • Nov 2011
              • 581
