Is it possible to replace the three main seals in the transfer case without opening the case up?
Replacing Seal in Transfer Case
Originally posted by z122643 View PostIs it possible to replace the three main seals in the transfer case without opening the case up?
the outputs i know you can (there are two on the front output shaft ,face to face ) and i did these and the rear output shaft seal in the car . the input shaft i don't know (can look at my spare manual T-case),and the factory manualAngus
88 E30M3 X2
89 325IX
92 R100GS/PD
Originally posted by z122643 View Postit's a manual. Can the front input shaft be removed without tearing the whole xcase apart?
so no you cant do all three seals without disassembling the entire T-caseLast edited by spdracrm3; 04-08-2013, 05:07 PM.Angus
88 E30M3 X2
89 325IX
92 R100GS/PD
Originally posted by nando View Postis there enough room to drive a 2nd seal in overtop of the old one? sometimes that works if the depth of material where the seal goes is great enough.
is the seal leaking? when it comes to the t-case - if it isn't broken, don't fix it...
I wish I really knew. The transmission leaked so much that it covered everything. I have no way of really knowing if the xcase is leaking or just has trans leakage all over it.
Having said that I still believe that it is leaking.[/SIGPIC]"we are so totally screwed!"
Originally posted by nando View Postis there enough room to drive a 2nd seal in overtop of the old one? sometimes that works if the depth of material where the seal goes is great enough.Angus
88 E30M3 X2
89 325IX
92 R100GS/PD
