Symptoms Of Transfer Case Chain Stretch?
  • z122643
    • Aug 2011
    • 286
    Title says it all. I got my iX 3 years ago and it was driven HARD! I just rebuilt the engine and it's running sweet.
    However it seems to have a jerk inbetween 1-3 gear shifts. (lets not jump on the "your shifting sucks" bandwagon) There is also a low thud that comes from the rear of the car when a shift is completed.
    Since the rebuild of the engine I have installed new guibos in both the front and rear driveshafts.
    To be clear this problem has been there since I got the car.
    My concern is that the 16year old pervious driver streched the chain in the transfer case.
    Thoughts, comments, advice appreciated
    Jack test revealed that the VC is about 75% Not great but not bad enough to replace.
    [/SIGPIC]"we are so totally screwed!"
    • 34839
    the chain doesn't really stretch. it might see some wear overtime, but basically, unless it was run dry of fluids it's not going to be significant.
    there's always some backlash in the drivetrain.
    it sounds like your bushings are simply shot.
    • z122643
      • Aug 2011
      • 286
      Taking about the diff and transfer/trans bushings ?
        • 34839
        subframe and trailing arm most likely
        • jute91
          • Nov 2011
          • 581
          There was huge difference between my old and new chain. Chain itself doesn't stretch, its the jointments of the chain which wear out and make it loose :D lol
          Also found on Facebook - Juuso Tero, Tampere
          https://www.facebook.com/JuusosGarage
            • 34839
            I know, it can wear - but it's a common, and incorrect meme that the ix transfercase chain "stretches".
            I have a 225,000 mile chain that is virtually indistinguishable from a brand new one I had - it was looser, of course, but it wasn't any longer.
            almost always the VC will be shot long before the chain wears out.. and the poor car will probably get parted due to rust & neglect. it's depressing to think about how many are parted out.
            • z122643
              • Aug 2011
              • 286
              I was quoted $1,600 for a new chain. Where do you guys get yours from?
                • 34839
                uhh, wow, from a dealer? a whole transfercase is only ~$2500!
                should be about $300.. you can get them stateside. I can't remember the manufacturer anymore.
