Rear Differential Rebuild/With Pictures
  • Wanganstyle
    • 2828
    #46
    Originally posted by z122643
    So where do you get your bearings from? I noticed your from the bay. I'm in the East Bay. (Sunol)
    Cheers
    Anywhere one desires?
    More than one place to order a standard item from.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    • z122643
      • Aug 2011
      • 286
      #47
      So which supplier has the best quality, and best prices?
      [/SIGPIC]"we are so totally screwed!"
      • The Dark Side of Will
        • Jun 2010
        • 2796
        #48
        So which manufacturer has the best quality, and best prices?
        Fixed.
        • z122643
          • Aug 2011
          • 286
          #49
          Originally posted by The Dark Side of Will
          Fixed.
          Thank You
            • Jun 2010
            • 2796
            #50
            What Wanganstyle was saying was that a given MFG's bearings will be the same from any distributor...
            SKF is probably the top Euro manufacturer; Timken the top US; drawing a blank on the top Japanese name...
            • Wanganstyle
              • 2828
              #51
              Skf bearings are sometimes germany sometimes japan sometimes brazil in origin.
              F.a.g. is usually germany
              Timken is usa.
              BMW OEM use is SKF or FAG.
              Bmw Never uses Timken OEM; I'm not 100% why the multi sourcing.
                • Jun 2010
                • 2796
                #52
                NSK
                Bearings are standardized in size according to ANSI, DIN or JIC standards, so different MFG's bearings should be dimensionally interchangeable.
                • z122643
                  • Aug 2011
                  • 286
                  #53
                  So…. here I go again. This time it's a full rebuild. New bearings, races, and seals. God help.
                  • 2002tiiguy
                    • Jul 2013
                    • 467
                    #54
                    So, what is this differential you speak of? I thought that was just for race cars ;-)
                    • rzerob
                      • Jun 2013
                      • 2315
                      #55
                      Subscribed
                      • z122643
                        • Aug 2011
                        • 286
                        #56
                        • z122643
                          • Aug 2011
                          • 286
                          #57
                          The bearings look a little worn ;p
                          Anyone know what the numbers mean?
                            • Jun 2010
                            • 2796
                            #58
                            And a little rusty.
                            • z122643
                              • Aug 2011
                              • 286
                              #59
                              And a little rusty.
                              understatement of the year!
                              • z122643
                                • Aug 2011
                                • 286
                                #60
                                Got some time to clean off the rust. Next the case… argh…
