Rear Differential Rebuild/With Pictures
  • z122643
    • Aug 2011
    • 286
    If it is good it will slip but very slowly and with a lot of resistance. Remember it's a LSD not a locked differential.
    [/SIGPIC]"we are so totally screwed!"
    • z122643
      • Aug 2011
      • 286
      So, I installed my rebuilt diff and now I can hear my radio... funny how that happens.
      Despite how bad the old diff looks the LSD is in excellent shape. I intend to rebuild this one and either keep it for a rainy day or sell it.
      • FredK
        • 14761
        Originally posted by z122643
        Now that I've got someone's attention. Anyone know how to get the pinion out?
        Either pound it out with a heavy dead blow hammer exactly in this state, or use a hydraulic press.
        • Wanganstyle
          • 2828
          A diff with old pinion bearings and races and Old LSD internals is NOT rebuilt
          BMW's kill the pinion bearings and races first; no amount of paint or clean up will "FIX" this.
          to replace them with NEW is the proper procedure; a NEW crush washer is needed to set the drag load.
          Originally posted by nando
          I could, but BMW used a VC back there for a reason - to some extent a clutch diff still needs one axle to have a load on it. a VC doesn't.
          a Clutch type LSD unit locks because the basket of spider gears in the middle wants to expand when One wheel is significantly different than the other; One wheel can be airborne and unloaded; it will Lock if internally proper.
          A viscous LSD uses HEAT from the wheel speed difference to lock up plates in fluid; its a REACTIONARY item that locks AFTER enough heat is put into it.
          • TehRaydarlover
            • Mar 2013
            • 544
            A viscous lsd uses a shear thickening silicone fluid not heat, hence VISCOUS lsd. The fluid increases viscosity with shear rate. The diff will lock after it reaches a high enough shear rate. An increase in temperature would if anything make the fluid less viscous.
            Build Thread
            Rear Diff Rebuild
            Rebuildable Viscous Coupling
            Transfer Case Rebuild
            "Life is simpler with 12 valves"
            • Wanganstyle
              • 2828
              We are both saying the same thing.
              Viscous silicone fluid still needs heat to work.
              Heat comes from wheel speed differences
              Sent from my SAMSUNG-SGH-I337 using Tapatalk
              • TehRaydarlover
                • Mar 2013
                • 544
                No heat has nothing to do with it. Its an unwanted byproduct.
                Build Thread
                Rear Diff Rebuild
                • Wanganstyle
                  • 2828
                  Google search how a viscous lsd works: Suabru and many others use them. Bmw uses a GKN VISCO-LOK viscous on e46m3 and e60 m5; im quite familiar with it.
                  If it was not heat expanding the silicon viscous fluid then how else would it lock up? MAGIC???
                  The viscous unit is a sealed capsule with fluid and discs inside. The silicon fluid gets hot and expands: locking happens then
                    • 34839
                    actually I agree with him - you have it wrong. viscosity increases because of shear, not because of heat. heat is just a byproduct.
                    • Wanganstyle
                      • 2828
                      Subaru factory explains it as heat expansion causing viscosity increase.
                      • TehRaydarlover
                        • Mar 2013
                        • 544
                        lol its a material property. Simple example: have you ever played with cornstarch and water??? It gets hard when you try to stir it. It does not get hot... a lsd is fundamentally the same thing
                        ^this
                        Build Thread
                        Rear Diff Rebuild
                        • Wanganstyle
                          • 2828
                          ^this
                          Chicken egg equation
                          Realistically the plates inside vlsd will expand with heat.
                          This is a math bee beteeen tmi school kids
                          • TehRaydarlover
                            • Mar 2013
                            • 544
                            How hot do you think it gets??? The plates will never expand enough to make the diff lock. If that was the case you would have to wait a while for the plates to cool down for the diff to open back up.
                            lol, yep. I am a senior ME student, I've done experiments with Newtonian and non-Newtonian fluids, and plotted the shear rate vs viscosity. The fluid in the vlsd is a silicone based dilatant fluid. Do some searches about vlsd on pages other than Wikipedia, you'll see what I'm trying to say.
                            Build Thread
                            Rear Diff Rebuild
                            • Wanganstyle
                              • 2828
                              A tiny bit. Not some extrene
                              Research and ask your professors
                              • TehRaydarlover
                                • Mar 2013
                                • 544
                                I've done the research and the experiments to prove it. Evidently you haven't.
                                Build Thread
                                Rear Diff Rebuild
