e30 ix transfer case seal
  • e30jps
    • Sep 2011
    • 285
    Hey everyone I notice the seal on the front shaft is leaking on the transfer case. Can I replace this seal with the transfer case installed in the car ?
    Of course first moving the drive shaft and etc.
    My 4awd drive works that was tested its just the seal is leaking?
    Thanks
    Jp
  • e30jps
    • Sep 2011
    • 285
    Well that sucks! If I have to take it apart I might as well replace the VC because the miles on my car is 220xxx and that's about when they go bad! :(
    • spdracrm3
      • Sep 2009
      • 959
      front output seals
      yes you can do the pair of front driveshaft output seals in the car ,did mine last year, just note one is in backwards and has the spring removed (basically becomes a dust shield) put tape on flange to protect seals as you install
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
        • 34844
        Originally posted by z122643
        Unfortunately no. The rear seal can be removed and replaced. But to get the front output shaft out you need to open up the case, which requires you remove the xcase from the car.
        No, this is wrong. you can install a new seal without removing the shaft. you need a pick to remove the old seals, and there's a special BMW tool that fits over the shaft to drive the new seals in (you used to be able to rent it from some places, or you could also make one most likely).
        • z122643
          • Aug 2011
          • 286
          ***NEVER MIND*** Total brain fart, got the input confused with the output. My bad, apologies.
          [/SIGPIC]"we are so totally screwed!"
          • e30jps
            • Sep 2011
            • 285
            Thanks for the help and the tips! If I remember I'll try to post pictures
            • e30jps
              • Sep 2011
              • 285
              Or maybe use a deep socket big enough to tap it in.
              • BAlbertiX
                • Apr 2011
                • 258
                2nd that. I need to do the same.
                '87 325is coupe
                previous:
                '91 325iX coupe
                '86 325e sedan
                • imwhyteyo
                  • 1165
                  i just posted a few pictures of my transfer case repair on my "lela" build page. taking a look at some of those pictures might give you the answer you need.
