Coupe of issues to hammer out
  • KDAWG97M3
    • Sep 2009
    • 347
    Fixed
  • Northern
    I like cupcakes & sh!tboxes
    • 5249
    Originally posted by KDAWG97M3
    Second issue is the speedo...I supposedly bought a good cluster, I have swapped out the gears, and the mileage is still not recording, and also the speedo will work sometimes, and then spike, then stop, then start again. Coolant gauge works, gas gauge, but the MPG stays pegged to the left all the time. Any ideas on how to fix?
    Check your speed sensor/connection/wiring at your diff. It is probably toast.
    Third issue, the power steering is out..I checked the reservoir and it is empty, and the pump isn't whining, so I guess that means the pump is toast..correct?
    Fire some ATF in there and see what happens. Is the belt attached?
    Originally posted by priapism
    Originally posted by shameson
    • KDAWG97M3
      • Sep 2009
      • 347
      I will check..
      Yes belt is on...
      • KDAWG97M3
        • Sep 2009
        • 347
        Bump....thanks
