IX rally car (german Ebay)
  • spdracrm3
    • Sep 2009
    • 959
    http://www.ebay.de/itm/BMW-325ix-E30...item35d08f34bf
    would like to see how this was done "With sports gearbox Getrag 240 ( from 635ci , 1st gear on the bottom left , 5th gear 1:1)"???
    from google translate
    Built in 1987, Max 1000 WP- km, no gravel ! ! total max . 10,000 km since complete rebuild in 2007
    - With sports gearbox Getrag 240 ( from 635ci , 1st gear on the bottom left , 5th gear 1:1)
    - Axis 4.10 , top speed about 175 km / h
    - Motor with a large and the throttle valve 3 jet nozzle 15% more passage
    - Forged crankshaft from 324td to 4kg easier / balanced
    - H- shaft and connecting rod 140mm, forged pistons JE Pistons Flat Top
    - Schrick camshaft 288Grad , 11.5:1 compression , turns loosely over 7,000 r / min.
    - Piston + connecting rod together approx 300g lighter than Series
    - All mounted and sealed new
    - Flywheel 5.2 kg (serial +10 kg ) , Sachs clutch
    - About 230hp with modified head
    - Large cooler ( tropical version )
    - SPAL electric fan with two stages thermal switch + separate switch
    - Large Mocal oil cooler
    - Switchable ABS is
    - Stainless Steel Manifold + Super Sprint ESD, 2 pcs 100 Zeller sport -KAT
    - Tarox brake system with 6-piston calipers
    - 280mm brake discs with aluminum pots at the VA, HA ventilated discs from IX- Touring
    - VA with 10mm track plates
    - Coilover suspension front and rear axles , each 2- Ferder system
    - Bilstein B6 dampers all round with a modified characteristic
    - VA with adjustable aluminum Domlagern with Unibal stock
    - All sockets PU
    - Cage homemade current status with H - brace , cross, double side protection and Harness Bar
    - Driver's seat Sabelt GT30 from 2011 , passenger seat Toora Project 2 of 2010
    - 6- point belts in 2007 ( nationally available in 2017)
    - 350mm steering wheel slightly dished , Terraphon Professional Intercom , reading lamp
    - Standing fly-off , braking force regulator, Series handbrake
    - Empty weight approx 1200kg
    - Makrolon side and rear windows
    - Conventional Front + Rear GRP
    - TÜV / AU is new on sale, vehicle is delivered logged
    - For class F3B , H15 , CTC ( CTC standard manifold and standard brake system at the VA) or Histo
    - For slalom , race track , drift or hillclimb
    or an IX touring
    http://www.ebay.de/itm/BMW-e30-325ix...item3f2e7a8ed8
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    That touring looks so sad.
    Originally posted by priapism
    Originally posted by shameson
