in a word no , the tailshaft housing is different to mount the T-case ,otherwise the transmissions are exactly the same . so you would need to put an IX tailshaft housing on it which requires almost complete dis-assembly so might as well just find an IX ....
Thank you! Just found one for $300 and it is in good working condition. Is that a decent price?
Just for the trans or the complete set up? You need the transmission, transfer case, transfer case mount, shifter assembly, clutch and flywheel, complete pedal box with clutch master and lines, clutch slave and lines, this is everything you need for the swap :-)
Sent from my GS4 Active
'91 318i (Alpine) - daily
'88 325ix (Zinno) - drive here and there!
clutch and flywheel are the same for the ix, so isnt the pedal box, clutch master, slave, and lines. only thing that differs is the transmission rear half itself, with the mounts of course.
