I will be replacing the front passenger axle seal between the oil pan and the carrier because it leaks a bit, I was wondering what fluid should I drain before attempting this, the engine oil or diff fluid, just so i dont remove anything unecessarely, ive done my diff not to long ago so it doesnt have to be done! Thanks!
Front axle seal replacement
hmmm... i have had so many of these apart and i can't say for sure. when you pull the axle, no oil runs out. is it the oring between the pan and carrier or the seal on the outside where the axle goes in?sigpic
Gigitty Gigitty!!!!
