H&R sports
  • duffyboby
    • Oct 2013
    • 75
    H&R sports
    Hi, I was wondering what kind of camber you saw with the H&R installed, im curious to see as i dont want to have crazy tire wear!
    88' 325iX 126k
    • 34844
    it barely lowers the car 1". it's not going to have a large effect on camber. improper toe will wear out tires faster than whatever camber gain you get from sport springs.
    • duffyboby
      • Oct 2013
      • 75
      Good to know, I just want the nose to come down a bit, even though its an iX im tired of the monster truck look.
      88' 325iX 126k
      • m3madness
        • Oct 2013
        • 36
        Are you expecting any tire rub? Is the ride better? Handling significantly better. I drove a 325e with HR suspension and it was pretty nice. Just not sure if messing with the ix would be the thing to do.
          • 34844
          it barely lowers it at all. it's not like you're dumping it 3" on some Chinese coilovers. :p
          rubbing isn't going to be an issue.
          • Isostar13
            • Nov 2011
            • 288
            I've been running H&R sports with Bilstein HDs since Jan 2012. No rub, no odd tire wear, etc. Looks great, drives great.
            edit: FYI I'm running stock IX weaves (15") with stock tire size (205/55/15).
            1988 325ix
            • imwhyteyo
              • 1165
              As long as eeverythng else is in check your solid. Ive had no troubles with wear. The drop is definitely not significant enough to do harm.
