front drivers shaft replacement
  • flowbro
    • Jan 2014
    • 5
    So, I pulled the front drivers side axel out and now trying to place it back into the T.C. side first. The shaft gose in 1/4 to a 1/3 in and stops . Do I pull out the retaining spring out and place on the grove of the axe then place it? any suggestions?
    Thanks for your time.
  • z122643
    • Aug 2011
    • 286
    The front axle doesn't go into the TC. I assume you mean the differential. You need to first line up the splines, then give the axle a good tap to overcome the tension of the clip inside the differential. *Important to line up the splines *Do not remove the clip
    [/SIGPIC]"we are so totally screwed!"
    • flowbro
      • Jan 2014
      • 5
      any suggestions how to line up the splines?
      thanks!
        • 34844
        Turn it.
