Front Lower Wishbone Rear Bush?
  • Nisse Järnet
    • Aug 2013
    • 1221
    Anyone knows if the standard E30 Powerflex bushing will work? Or is something different on the ix?
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
    • 34839
    they are the same, yes it will work.
    • Nisse Järnet
      • Aug 2013
      • 1221
      Thanks!
      I noticed that the lollipops were the same but the bushing had a different part nr, i assume thats because the 4wd maybe needs more rubber in the bushing?
        • 34839
        yeah it has less void area.
        I personally like the solid M3 and offset M3 bushings
        • Nisse Järnet
          • Aug 2013
          • 1221
          Those with rubber in the whole bushing?
            • 34839
            yeah
            • fresh_TD
              • Aug 2013
              • 2457
              whats the benefit from using the M3 offset bushing instead of the stock ones?
              Sent from my Samsung Note 3
              '91 318i (Alpine) - daily
              '88 325ix (Zinno) - drive here and there!
              • mtech325
                • May 2008
                • 568
                For starters they're solid rubber as opposed to the webbed design, but the main point is that they give you more caster, which the iX lacks from the more upright strut towers. I think stock the iX has like 1 or 2 degrees of caster. I'm sure Nando will be able to give the specifics on this. It's been a few years now since I've had an iX :(
                  • 34839
                  yeah it's something like 1-2 degrees stock. I think I have like 3.5 degrees with camber plates and offset bushings, lol.
